Unbalanced Three-phase circuit.
  • Context: Engineering
  • Thread starter Thread starter jfierro
    Circuit Three-phase
The discussion centers on solving an unbalanced three-phase circuit problem from Alexander's and Sadiku's "Fundamentals of Electric Circuits" (3rd edition). The user initially attempted to calculate line currents using two methods: phase voltage division and a complex coefficient matrix. The correct line current, I_a, was determined to be (64|80.1º) after correcting errors in vector algebra and matrix formulation. The final matrix setup was confirmed as accurate, leading to the correct solution.
  • Understanding of three-phase circuit theory
  • Familiarity with complex numbers and phasor notation
  • Proficiency in using matrix operations for circuit analysis
  • Knowledge of trigonometric functions, particularly sine and cosine
  • Study the application of complex numbers in electrical engineering
  • Learn about three-phase power calculations and their significance
  • Explore matrix methods for solving electrical circuits
  • Review vector algebra and its applications in circuit analysis
Electrical engineering students, circuit designers, and professionals involved in power systems analysis will benefit from this discussion.
jfierro
[SOLVED] Unbalanced Three-phase circuit.
This comes from "practice problem" 12.10 from Alexander's and Sadiku's Fundamentals of Electric circuits 3rd edition, chapter 12.
The problem statement is:
"Find the line currents in the unbalanced three-phase circuit of Fig. 12.26 and the real power absorbed by the load."
http://img413.imageshack.us/img413/8428/circuits.png
- LCK
The problem is I can't get to the shown answer. I have followed two methods:
Getting I_AB and I_CA from the known phase voltages:
I_AB = (220|0º) / (5|-90º)
I_CA = (220|-120º)/(10|0º)
And then doing I_a = I_AB - I_CA.
The second method is to construct a 3x3 matrix with complex coefficients based on the three meshes shown in the circuit. For those of you familiar with mathematica notation my matrix is:
LinearSolve[{{-5 I, 5 I, 0}, {5 I, 10 + 5 I, -10 I}, {0, -10 I, 10 I}}, {220, 0, -110 + Sqrt[3]*0.5*I}]
where I is the imaginary number and the first solution would be I_a.
Both methods yield 11 + 44.866i, far different from the listed result.
Any idea of how the authors got to (64, 80.1º)?
I just did exactly what you said using my beautiful vector-capable TI-89 and got the book's answer. I assume you did something wrong with your vector math.
I_AB = (220|0º) / (5|-90º) =(44|90º)
I_CA = (220|-120º)/(10|0º) = (22|-120º)
I_a = I_AB - I_CA = (44|90º) - (22|-120º) = (64|80.104º)
Hmm it was indeed a problem of my vector algebra ^_^u. I was doing them by hand and when getting the imaginary part of I_CA I did only sin(-120º) and not 22sin(-120º)...
I made the same mistake when constructing the matrix, the matrix should've been:
[tex]\begin{bmatrix} -5j & 5j & 0 \\ 5j & 10+5j & -10j \\ 0 & -10j & 10j \end{bmatrix} \begin{bmatrix} I_a\\ I_b\\ I_c \end{bmatrix} = \begin{bmatrix} 220 \\ 0\\ -110 + 220\frac{\sqrt{3}}{2}j \end{bmatrix}[/tex]
Since sin(120º) = 0.5sqrt{3}.
Thanks! :D
12K
