| Thread Closed |
Single-Slit Diffraction |
Share Thread | Thread Tools |
| May7-10, 10:57 AM | #1 |
You have been asked to measure the width of a slit in a piece of paper. You mount the paper 80.0 centimeters from a screen and illuminate it from behind with laser light of wavelength 633 nanometers (in air). You mark two of the intensity minima as shown in the figure, and measure the distance between them to be 17.9 millimeters. ![]() 2. Relevant equations sin([tex]\theta[/tex])=m[tex]\lambda[/tex]/a Also for small angles [tex]\theta[/tex] sin[tex]\theta[/tex] = tan[tex]\theta[/tex] = [tex]\theta[/tex] 3. The attempt at a solution I'm not really sure how to set up the equation. I'm used to having questions giving me the width of the central fringe and not the distance between 2 minima. How do I use the given distance between the paper and screen and the distance between the two minima in the picture to calculate sin[tex]\theta[/tex] I'm also unsure what m would be equal to in this case. Thanks |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May7-10, 10:12 PM | #2 |
Recognitions:
Put θ = y/x, where y is the diatance of the mth dark fringe from the center and x is the distance between slit and the screen. In this problem it is 17.9/2 mm.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Single-Slit Diffraction
| FFT Single slit diffraction | General Physics | 5 | ||
| single-slit diffraction | General Physics | 2 | ||
| Single Slit diffraction | Introductory Physics Homework | 2 | ||
| Single slit diffraction | Introductory Physics Homework | 1 | ||
| Help!! Single slit diffraction | Introductory Physics Homework | 20 | ||
