Graphing Frequency Spectrum of Signal Over Time
This discussion focuses on graphing the frequency spectrum of a signal over time using a specific filter equation: y_n = Ae^{i\omega_0}y_{n-1} + x_n. The frequency response is defined as \frac{1}{\sqrt{(1-A)^2 + 2A(1-\cos(\omega - \omega_0))}}, which peaks at \omega_0. The user encountered an issue where the calculated contribution \widehat{x} did not yield expected results, ultimately identifying a programming bug where \widehat{x} was incorrectly assigned to \left|y_{-1}\right|. This highlights the importance of debugging in signal processing implementations.
  • Understanding of digital signal processing concepts
  • Familiarity with Z-transforms and their applications
  • Proficiency in programming for signal processing (e.g., Python, MATLAB)
  • Knowledge of filter design and frequency response analysis
  • Study Z-transform applications in signal processing
  • Learn about digital filter design techniques
  • Investigate debugging strategies for signal processing algorithms
  • Explore visualization tools for frequency spectrum analysis
Signal processing engineers, software developers working on audio analysis, and researchers in the field of digital signal processing will benefit from this discussion.
Gigasoft
I am trying to graph the frequency spectrum of a signal over time. To do this, for each frequency I use a filter defined by the following equation:
[tex]y_n = Ae^{i\omega_0}y_{n-1} + x_n[/tex]
This has a frequency response of [tex]\frac 1 {\sqrt{\left(1-A\right)^2+2A\left(1-cos\left(\omega-\omega_0\right)\right)}}[/tex], which peaks at [tex]\omega_0[/tex].
Now, for every m steps I want to find out how much [tex]x_n[/tex] contributed to [tex]|y_n|[/tex] during the last m steps. I define [tex]\widehat{y}_n=H\left[n\right]\left|y_n\right|[/tex], where n=0 is the first of the last m steps and H is the unit step function, and I let [tex]\widehat{x}[/tex] be the contribution of x to |y|, which I assume to be constant for the m samples under consideration. This gets me the equation [tex]\widehat{y}_n=A\widehat{y}_{n-1}+\delta\left[n\right]A\left|y_{-1}\right|+H\left[n\right]\widehat{x}[/tex].
The Z-transform of this equation is:
[tex]\left(1-Az^{-1}\right)\widehat{Y}\left(z\right)=A\left|y_{-1}\right|+\frac{\widehat{x}}{1-z^{-1}}[/tex]
In other words,
[tex]\widehat{Y}\left(z\right)=\frac{A\left|y_{-1}\right|\left(1-z^{-1}\right)+\widehat{x}}{\left(1-z^{-1}\right)\left(1-Az^{-1}\right)}[/tex]
This can be written as:
[tex]\widehat{Y}\left(z\right)=\frac C{1-z^{-1}}+\frac D{1-Az^{-1}}=\frac{C\left(1-Az^{-1}\right)+D\left(1+z^{-1}\right)}{\left(1-z^{-1}\right)\left(1-Az^{-1}\right)}[/tex]
From the two equations about, [tex]A\left|y_{-1}\right|+\widehat{x}-A\left|y_{-1}\right|z^{-1}=C+D-ACz^{-1}-Dz^{-1}[/tex] for all z, and we must have [tex]A\left|y_{-1}\right|+\widehat{x}=C+D[/tex] and [tex]Ay_{-1}=AC+D[/tex].
The inverse transform of [tex]\frac C{1-z^{-1}}+\frac D{1-Az^{-1}}[/tex] is [tex]H\left[n\right]\left(C+DA^n\right)[/tex]. So, we have [tex]C+DA^{m-1}=\widehat{y}_{m-1}[/tex].
This gives:
[tex]D=A\left|y_{-1}\right|-AC=\frac{\widehat{y}_{m-1}-C}{A^{m-1}}[/tex]
[tex]A\left|y_{-1}\right|-\frac{\widehat{y}_{m-1}}{A^{m-1}}=C\left(A-\frac 1{A^{m-1}}\right)[/tex]
[tex]\left|y_{-1}\right|-\widehat{y}A^{-m}=C\left(1-A^{-m}\right)[/tex]
[tex]C=\frac{\left|y_{-1}\right|-\widehat{y}_{m-1}A^{-m}}{1-A^{-m}}=\frac{\left|y_{-1}\right|A^m-\widehat{y}_{m-1}}{A^m-1}=\left|y_{-1}\right|+\frac{\widehat{y}_{m-1}-\left|y_{-1}\right|}{1-A^m}[/tex]
[tex]\widehat{x}=C+A\left|y_{-1}\right|-AC-A\left|y_{-1}\right|=\left(1-A\right)C=\left(1-A\right)\left(\left|y_{-1}\right|+\frac{\widehat{y}_{m-1}-\left|y_{-1}\right|}{1-A^m}\right)[/tex]
However, when I apply the last formula to the result of the first filter in my program, I don't get [tex]\widehat{x}[/tex]. If x is 0, then [tex]\widehat{x}[/tex] should be 0 as well, but it isn't. The formula looks correct. I have tried with a value of m as low as 2, but it still doesn't work. What could be the problem.
Oh, nevermind. I had a bug in the program where I accidentally used [tex]\widehat{x}[/tex] for [tex]\left|y_{-1}\right|[/tex] for the next iteration.
  • · Replies 36 ·
10K
10K
