Calculate the magnitude and direction of the resultant force on the object.
The discussion revolves around calculating the resultant force on an object subjected to multiple forces, specifically a 9N force in one direction and 3N and 4N forces in the opposite direction. The problem also involves determining the acceleration of the object given its mass.
  • Mixed
  • Participants discuss the interpretation of forces as positive or negative, and how to calculate the resultant force. There is also a mention of the need for mass to solve for acceleration.
Some participants have provided guidance on how to approach the calculation of the resultant force and have clarified the significance of the object's mass in determining acceleration. Multiple interpretations of the direction and magnitude of forces are being explored.
The problem specifies a mass of 0.5 kg for the object, which is essential for calculating acceleration. There is some confusion regarding the signs of the forces and their implications for direction.
Cheesus128
Hey,
I have the following question.
How do I work this out:
There is an object 9N<-----------[OBJECT]--->3N--->4N...[The ---> represent the direction in which the object is being pulled, and the 3N and 4N pull into the same direction.
Now its asking me:
1. Calculate the magnitude and direction of the resultant force on the object.
2. Calculate the magnitude of the acceleration of the object.
Could someone please help me find the answer?
And if anyone knows the answer could they please explain how they got it?
Thank you.
state the problem in exact language.
What do you mean?
Thats exactly what it says on my paper..
For part A, just call <----- negative and ------> positive. -9 N + 7 N = -2 N.
I don't think part B is solvable without knowing the mass of the object.
It says it has a mass of 0.5KG.
So for part A the answer for magnitude would be -2 and the direction would be "left"?
Almost. The magnitude is 2 and the direction is left. If the magnitude were -2 and the direction was to the left left, the motion would actually be to the right. That may be a bit confusing- does it make sense to you?
Now that you know the mass, you can use F=ma to find the magnitude of the acceleration.
Hey yeah good sense.
Two negatives make a positive kinda thing.
ok So F=ma perfect thanks!
  • · Replies 50 ·
10K
