[thermo] pressure & steam tables related question
This discussion focuses on calculating the weight of a lid required to boil water at specific temperatures using steam tables and pressure calculations. The user determined that water boils at 110°C under an absolute pressure of 143.27 kPa, leading to a gauge pressure calculation that resulted in an estimated lid weight of approximately 76.14 kg. The conversation also explores a similar scenario for boiling at 120°C, yielding different lid weights based on absolute and gauge pressure calculations. The consensus emphasizes using absolute pressure for accurate force equilibrium analysis.
  • Understanding of steam tables and boiling point calculations
  • Knowledge of pressure concepts: absolute pressure vs. gauge pressure
  • Familiarity with basic physics formulas: force, mass, and area
  • Experience with pressure-related calculations in fluid mechanics
  • Research the principles of steam tables and their applications in thermodynamics
  • Learn about the differences between absolute pressure and gauge pressure in practical scenarios
  • Explore fluid mechanics concepts related to force equilibrium and pressure calculations
  • Investigate the effects of atmospheric pressure variations on boiling points
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in pressure-related calculations for boiling liquids.
gematt7
you want to boil a pot of water at 110 C
diameter of pot = 15cm
atmospheric pressure 101 kPa
what weight lid should you use?
i looked up the steam tables and water boils at 110 C at 143.27 kPa
so do i use that pressure or 143.27-101? (gauge pressure)
i used gauge and got something like ~76.14 kg.. which seems ridiculous for a lid weight
formula i used:
force = mass x 9.81
force = pressure * area
mass x 9.81 = pressure * area
_____________________
similar question but area = 5mm^2, atmospheric pressure = 101.3 kPa, and you want it to boil at 120 C
i got an answer of 0.101kg using absolute pressure and 0.049kg using gauge pressure
could you verify my answer and tell me which pressure i should be using.. absolute pressure or gauge pressure
if you think about it, the force equilibrium is:
PinA = Wlid + PatmA
or
(Pin-Patm)A = Wlid
PgaugeA = Wlid
oh thanks you.. force equlibrium is a better way of looking at it :)
  • · Replies 19 ·
  • · Replies 19 ·
