Was the Original Law of Conservation of Parity Flawed?
The discussion revolves around the law of conservation of parity, particularly its validity and the implications of its violation as demonstrated by Chien-Shiung Wu's experiments. Participants explore the theoretical foundations of parity conservation and the potential flaws in the original theory, as well as its implications in the context of particle physics and general relativity.
  • Some participants note that until 1956, parity conservation was widely accepted in all physical interactions, which was challenged by Wu's experimental findings on beta decay.
  • There is a question regarding the specific flaw in the original theory of parity conservation, with some participants suggesting that the theory lacked a solid basis for assuming parity would always be conserved.
  • One participant proposes that if the equations governing a particle exhibit transformations that maintain invariance under spatial reflection, then parity should be preserved, but this requires independent solutions to support parity violation.
  • Another viewpoint suggests that the original tensor formulation of general relativity may contain an implicit assumption of spatial reflection invariance, which could be a source of the flaw, contrasting it with a later formulation that avoids this assumption.
Participants express uncertainty regarding the specific flaws in the original theory of parity conservation, and multiple competing views remain about the implications of Wu's findings and the theoretical underpinnings of parity conservation.
Some discussions highlight the dependence on definitions and the unresolved nature of the assumptions regarding spatial reflection invariance in the context of the original theory.
jobsism
I had read an article about the law of conservation of parity was disproved by a columbian physicist,Chien-Shiung Wu through experimental basis. My doubt is whether there was a flaw in the original theory of the law.If yes, then where was it?
Until 1956, the conservation of parity was thought to hold in in all physical interactions.
In that year, Chien Shung Wu, of Columbia university and two National Bureau of Standards physicists, Drs. Ambler and Hoppes, showed that the parity is not conserved in beta decay of the Cobalt nucleus. The experiment was suggested by T. D.Lee, and
C. N.Yang for which they received the Nobel prize.
But the flaw in the theory...where was it?
My understanding is that if the equations for the particular particle have transformations that leave spatially reflected operations invariant with respect to non-reflected operations then parity is always preserved. To support parity violation the equation must have independent solutions.
The flaw in the theory was just that there was no real basis to expect parity to be conserved.
If every term in an interaction behaves the same under reflection of coordinates, then parity would be conserved, but there is no reason to require this.
It may be that the original tensor formulation of GR and related group, with only 10 parameters, contains an implicit assumption of spatial reflection invariance. The group yielding 16 parameters, which was discovered after an analysis by Einstein and another physicist or mathematician of spin effects in the 1930's was shown to avoid that assumption.
  • · Replies 19 ·
