| Thread Closed |
How to read this file line by line and store contents in an array |
Share Thread | Thread Tools |
| May11-10, 06:11 PM | #1 |
Hello,
In my computational science class I have the task of taking the following input file and manipulating it. I have the following input file: C1 0 0.00 0 000.0 0 000.0 O2 1 1.22 0 000.0 0 000.0 H3 1 1.09 2 120.0 0 000.0 C4 1 1.54 2 120.0 3 180.0 H5 4 1.09 1 110.0 2 000.0 H6 4 1.09 1 110.0 2 120.0 H7 4 1.09 1 110.0 2 -120.0 stored as input.txt. I need to open this file, read each line, and store each line as an element in an array. Is this even possible in C? I am used to Java, where I could have stored each line as a string object, but in C I have no idea. After that , I need to be able to access each element in this array, open an element, and tokenize it by space delimiter. Can someone please show me a code example of how this is done? I have spent several days browsing the internet looking for help in how this works, but I have had no such success. I'm really demoralized right now. Thank you, miss fangula |
| May11-10, 06:15 PM | #2 |
Oh, this is the code I have so far (not much, I know!):
#import <Foundation/Foundation.h> int main () { FILE* input; //file pointer to input file FILE* output; //file pointer to output file input = fopen("input.txt", "r"); //open input file to read output = fopen("output.txt", "w"); //open output file to write if (input == NULL) { fprintf(output, "Error opening file."); } fclose(output); fclose(input); return 0; } |
| May11-10, 10:50 PM | #3 |
Recognitions:
If your C++ compiler supports <iostream>, you can use getline() to retrieve lines. There's also a <string> version of getline() if your compiler supports standard template libarary. If this is C and not C++, on a modern PC, you probably have enough ram to be able to allocate a large amount of memory (malloc()), read the entire file into memory, after which you can use memchr() to scan the buffered data for line terminators.
| Thread Closed |
| Thread Tools | |
Similar Threads for: How to read this file line by line and store contents in an array
| Vector equation for a line passing through a point and perpendicular to another line | Calculus & Beyond Homework | 11 | ||
| How to read always from the first line when using READ in a loop? | Programming & Comp Sci | 1 | ||
| C++ How do I call a specific line from an input file? | Programming & Comp Sci | 5 | ||
| Find the equation of the normal line of the given parabola that is parallel to a line | Calculus & Beyond Homework | 9 | ||
| change the contents of a file into a string | Programming & Comp Sci | 2 | ||
