Differential/Integration equation manipulation
  • Thread starter Thread starter orangesun
    Manipulation
The discussion revolves around solving two differential equations. The first equation involves manipulating the expression dy/dx = x(y²+3)/y, while the second equation is dy/dx = x²y with an initial condition y(1) = 1.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss separating variables for both equations. The original poster attempts to manipulate the first equation using substitution but expresses uncertainty about the approach. Others suggest separating variables as a clearer method. For the second equation, the original poster outlines their steps and seeks validation of their reasoning.
Some participants affirm that both equations are separable and provide guidance on how to approach the integration. There is a mix of attempts and confirmations regarding the methods used, particularly for the second equation, where initial conditions are noted as a next step.
Participants are navigating the complexities of integrating functions of y and x, with some noting the challenges of integrating without knowing certain functions. The initial conditions for the second equation are also highlighted as a critical aspect of the discussion.
orangesun
a) Solve the differential equation
dy/dx = x(y2+3)/y
b) Find the unique function y(x) satisfying the differential equation with initial
condition
dy/dx = x2y, y(1) = 1
With question a) I am no entirely sure but I have done
dy/dx = x(y2+3)/y
Let u = y2+3/y
So dy/dx = x.u
Integral of (dy/dx) = Integral (x.u)
y = x2u2/2
Then sub it back in. I'm not entirely sure
With question b) I have done
dy/dx = x2y
dy . 1/y = x2dx
integral of(1/y dx) = x3/3 + c
Ln y = x3 /3 + c
I am not sure if I am on the right track,
I would appreciate any help.
Thanks
For a), try putting all the 'y's by the dy and all the x's by the dx like you did in part b
Part b is correct. Now just sub in the condition y(1)=1
as rock points out, they're both separable
dy/dx = x(y2+3)/y
This is equivalent to
[tex]\frac{y}{y^2+ 3} dy= x dx[/tex]
Integrate both sides.
condition
dy/dx = x(y2+3)/y
Let u = y2+3/y
So dy/dx = x.u
y = x2u2/2
No, [itex]\int (dy/dx) dx= \int x u dx[/itex] but u is a function of y which is a function of x itself so you really have [itex]\int x f(x)dx[/itex] which cannot be integrated since you don't know "f(x)". Instead separate, as I suggested, and integrate the function of y with respect to y, the function of x with respect to x.
dy/dx = x2y
dy . 1/y = x2dx
Ln y = x3 /3 + c
Thanks
Yes, what you have done for this is correct. Now, use the condition that when x= 1, y= 1 to solve ln(1)= 0= 13/2+ c for c.
  • · Replies 25 ·
