Which wheel moves faster: the smaller or larger one?
  • Context: High School
  • Thread starter Thread starter TheMathMan
    Wheel
The discussion revolves around the question of which wheel, smaller or larger, moves faster in the context of a tractor and cart with differently sized wheels. The scope includes conceptual understanding of speed, both linear and rotational, as well as basic physics principles related to motion.
  • Conceptual clarification, Debate/contested, Mathematical reasoning
  • One participant asserts that if the tractor is moving at a certain speed, all wheels are moving at that same speed along the ground.
  • Another participant explains that while all wheels move at the same linear speed, the rotational speed (RPM) of the smaller wheel is higher than that of the larger wheel.
  • A participant elaborates on the relationship between linear speed and rotational speed, stating that the rotational speed is inversely proportional to the radius of the wheel.
  • There is acknowledgment that the interpretation of "fastest" can lead to different conclusions, with some focusing on rotational speed and others on linear speed.
  • One participant confirms that if considering horizontal speed, both wheels would indeed be moving at the same speed, while the smaller wheel would rotate faster.
Participants generally agree that all wheels move at the same linear speed when attached to the same cart, but there is disagreement on the interpretation of "fastest" regarding rotational speed versus linear speed.
The discussion highlights the ambiguity in the wording of the question and the assumptions made about what "fastest" refers to, which may lead to different interpretations and conclusions.
TheMathMan
OK. Our department at college has a question... none of us are science teachers.
A tractor and cart, all with different sized wheels, which travels fastest?
The answers are available are for any of the wheels ( smallest to biggest) or for all being the same?
My argument is, if the tractor is moving at say 20mph then all the wheels are moving at 20mph?
I'm sure this is an easy question for this forum. I did search buit couldn't find anything this low level.
They would all be moving at the same speed. The rotation RPM (revolutions per minute) of the smaller tire would be higher then that of the larger.
Obviously, if all wheels are rigidly attached to the cart, they all move along the ground at the same speed as the cart. But their rotational speed differ.
If the cart is moving at v m/s, a wheel, of radius r m, must turn fast enough that, in one second, its circumference moves v meters. Since its circumference has length [itex]2\pi r[/itex], it moves through that length in one revolution. It will move v m in [itex]v/(2\pi r)[/itex] revolutions so to move at speed v m/s, it must rotate [itex]v/(2\pi r)[/itex] revolutions per second. Note that r is in the denominator so rotational speed is inversely proportional to radius.
Thanks for the replies.
I assume the big difference in opinions on this is due to the wording of the question as to how you interpret "fastest".
So technically, if we were talking about rotational speed then it would be the smaller wheel moving fastest, but if we assume a mph then they'd be equal?
Bear in mind this is just from a pretty basic aptitude test, along with questions such as which number is missing from the sequence etc etc.
That is correct.
If you assume the speed along the X axis (horizontal vector) then both are moving 20mph.
If you assume the speed of rotation then the smaller tire would be rotating faster.
  • · Replies 35 ·
  • · Replies 69 ·
18K
66K
  • · Replies 38 ·
