| Thread Closed |
Confusing Force function |
Share Thread | Thread Tools |
| May13-10, 11:34 AM | #1 |
The force on a particle is directed along an x axis and given by [tex] F = F_0(\frac {x}{x_0} -1) [/tex]. Find the work done by the force in moving the particle from x = 0 to [tex] x = 2x_0 [/tex] 2. Relevant equations F=ma, W=Fd, etc. 3. The attempt at a solution I don't even know how to interpret that function. Does the [tex] x_0 [/tex] mean the initial position? Does [tex] F_0 [/tex] mean the initial force? I'm so confused. Any help would be appreciated. |
| May13-10, 12:15 PM | #2 |
Hi DrummingAtom!
![]() (try using the X2 tag just above the Reply box ) …a "0" subscript always means a constant (usually the value at t = 0). ![]() (oh … except in relativity, where x0 means time! )
| May13-10, 07:32 PM | #3 |
I'm still confused on this one. So, if x0 F0 are constants then how would the graph of this function look? Because they want you to graph F(x) before integrating. I mean what do you pick for your constant in a situation like this? I know it's going to be a linear function.
| May13-10, 08:19 PM | #4 |
Confusing Force function0....x0...2x0...3x0... Now when you consider your graph's labels, you are integrating from 0 to 2x0, as the problem specifies! The y-axis is F. So where does F0 fit into your graph? I'll let you do that. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Confusing Force function
| Confusing/tricky question about force | General Physics | 2 | ||
| Dirac delta function - its confusing | Calculus | 7 | ||
| Force statements. CONFUSING... | Introductory Physics Homework | 6 | ||
| [Q]Some confusing about Dirac Delta Function | Quantum Physics | 4 | ||
| Confusing force problem | Introductory Physics Homework | 13 | ||
