Hybrid Electric Transit Bus Powertrain Design
The discussion focuses on sizing the electric motor for a hybrid electric transit bus powertrain. Key considerations include calculating the required power based on vehicle speed (Vf), base speed (Vb), and the need to overcome drag, friction, and hill climbing. The rated power of the motor must meet or exceed the calculated requirements, which involve experimental determination of drag and friction forces. The final vehicle speed should reflect the operational range, particularly focusing on the 0-40 kph region for optimal performance.
  • Understanding of hybrid electric bus powertrain components
  • Familiarity with vehicle dynamics and acceleration equations
  • Knowledge of drag and friction forces in vehicle operation
  • Basic principles of power calculation in mechanical systems
  • Research methods for calculating drag and friction forces in transit buses
  • Learn about electric motor specifications for traction applications
  • Explore power calculation techniques for hill climbing scenarios
  • Investigate the impact of varying vehicle speeds on motor performance
Engineers and designers involved in hybrid electric vehicle development, transit authorities planning bus specifications, and anyone interested in optimizing electric motor performance for public transportation applications.
pchoopanya
Hello,
I am in the beginning of sizing all the components in the powertrain and really need your help;
I am trying to size the motor for a hybrid eletric bus
All articles I have read so far mention one lengthy equation that to know the rated power of the motor, one mush use;
PEM = [M(Vf2 + Vb2)/2ta] + ... + ...
Where Vf = the final vehicle speed
Vb = Vehicle base speed
ta = time to accelerate from 0 m/s to the desired speed
here are my questions;
1. In sizing the electric motor for traction application (to be used with a bus), am I in the correct direction? If not, what is the approach?
2. By saying the rated power of motor, does it actually meanthe maximum power that the motor could provide?
3. About the Vf, final velocity of vehicle >>> I am not sure what to use, could it be only sigle value which is the maximum speed of a bus which is 60 kph? Do I need other intermediate values, like 0-10 kph, 0-20 kph, 0-30 kph
However, the bus will have to operate most frequently in 0-40 kph region, shall I use Vf = 40 kph instead?
4. About the Vb, I understand the definition of motor base speed, but in the equation I need the vehicle speed, don't I? So, where do I find this value? What does this value depend upon?
Thank you very much
Yes rated does mean maximum. Once you calculate the required power, you find a motor that can provide at least that much, possibly more.
There are three considerations:
  1. Power to overcome drag and friction at maximum bus speed. This can not be calculated, you need to determine it by experiment.
  2. Power to accelerate. Those equations you cite are for that. If top speed is 50, how many seconds to accelerate from 0 to 50?
  3. Power to climb hills. You need to determine the steepest hill and the highest speed you will require from the bus. Then use poer=force*velocity where force is the weight of the bus and load, velocity is the vertical speed of the bus, not the horizontal.
  • · Replies 16 ·
