Product of singular matrices = the zero matrix
The discussion revolves around the properties of singular matrices, specifically the product of two matrices resulting in the zero matrix. The original poster presents a scenario involving a random 6x6 matrix A and its transpose B, questioning why the product AB should equal the zero matrix given that A is singular.
  • Participants explore the implications of Ax equaling zero and its relationship to the product AB. They question the reasoning behind the assertion that the product of two singular matrices results in the zero matrix. Some participants attempt to analyze the structure of matrix A and its columns, particularly the sixth column, to understand the conditions leading to Ax being zero.
The discussion is ongoing, with participants providing hints and prompting each other to clarify their understanding of why Ax equals zero. There is a focus on dissecting the mathematical reasoning rather than reaching a consensus or conclusion. Some guidance has been offered regarding the nature of matrix multiplication and the implications of singularity.
Participants are working within the constraints of a homework assignment, which may limit the information available for discussion. There is an emphasis on understanding the definitions and properties of singular matrices without assuming prior knowledge of the specific matrices involved.
clope023
A = floor(10*rand(6)) (6x6 matrix with random numbers)
B = A'(transpose)
A(:,6) = -sum(B(1:5,:))' (sum row 1st through 5th row entries and place in the 6th column and then transpose and take the negative)
x = ones(6,1) (vector with 6 entries all equal to 1)
Ax = 0, x=/=0 implies A is a singular matrix since it is in contradiction to the fact that a nonsingular matrix implies x=0 is a unique solution of the equation Ax=0
[1:6] (vector with 6 entries from 1 to 6 respectively)
B = x*[1:6] (matrix column of 1's, column of 2's, ..., column of 6's)
The product AB should be the zero matrix. Why?
det(A) = 0 => singular matrix
set O = zero matrix
therefore AB = O take determinant of both sides det(AB) = det(O) => det(A)det(B) = det(O)
0det(B) = 0, therefore 0 = 0, I also calculated the determinant of matrix B with MATLAB and it seems it was singular as well so more easily I can calculate (0)(0) = det(O) => 0 = 0
I also attempted the question without the use of the determinant
assuming B is nonsingular
AB = O, ABinv(B) = Oinv(B), AI = O, A = O -> contradicts the original statement that A was not the zero matrix orignially this also implies there does not exist an inverse of B and thus B is also singular
I'm not sure if this is the correct to infer that the product of these two matrices is necessarily the zero matrix without using determinants from here any help would be appreciated thank you
Why, exactly, is Ax equal to zero? What does this mean regarding the matrix product AB?
Note: I am not asking because I disagree. Those questions are big fat hints.
Ax = 0 would be because x=0 but x = ones(6,1) so this would imply that A = 0 however A was already a matrix =/= 0 so how could that be the zero matrix?
No. x is not zero, and neither is A.
B is equal to the vector [1:6] call it d
therefore B = x*d
AB = A*x*d = 0*d = O
not sure if that's quite it but closer I think
B is not equal to the vector 1:6.
Why is Ax zero? Yes, you were told that it is zero. Don't just take this as a given. Understanding exactly why Ax=0 will help you understand why AB=0.
sorry B=x*[1:6] mistyped on the keyboard
well the multiplcation of A*x will equal the zero vector since the summation of each row multiplied by the column of 1's inside the vector x will be equal to zero therefore the product is equal to a vector of 0's, the same procedure will yield a matrix of zeros for the product AB? I think the explanation should be simpler than this no?
Try again. Why exactly is Ax equal to zero? Write it out.
Hint: What is the sixth column of A?
I'm really not sure what your getting at by emphasising 'exactly'
the 6th column of A is composed of the negative of the summation of entries in each column element's particular row
this is another reason why when multiplied by vector ones(1,6) the product Ax = 0, this implies many solutions?
I'm still not sure how it applies unless the multiplication of A*x is somehow transferred over into the multiplication of A*B
That is *the* reason why Ax=0.
You appear to be thinking that because the determinant of some matrix is zero then that means that Ax will be zero for any vector x, and that AB will be zero for any matrix B. That is not the case. Example:
[tex]A=\bmatrix 1 & 0 \\ 0 & 0\endbmatrix[/tex]
While this matrix A is not constructed along the lines of the problem at hand, it certainly is singular. Yet A2 is not the zero matrix. In fact, A2=A.
This matrix is analogous to the problem at hand:
[tex]A=\bmatrix 1 & -1 \\ 2 & -2\endbmatrix[/tex]
This is once again singular, and
[tex]A\bmatrix 1 \\ 1 \endbmatrix = \bmatrix 0 \\ 0 \endbmatrix[/tex]
However,
[tex]A\bmatrix 1 \\ 0 \endbmatrix = \bmatrix 1 \\ 2 \endbmatrix[/tex]
Obviously not the zero vector.Back to the problem at hand: Suppose you replaced the last one in the unitary x vector with a zero. In that case, Ax is almost certainly not equal to zero.
so it is simply that the multiplication of rows of A and columns new B matrix will add to the zero vector? I thought there'd be more to it than that
THey won't add to the zero vector. AB is a matrix, not a vector.
correction the multiplication adds up to zero elements in a matrix, correct? thank you very much for all the help and your patience btw
Correct, and you're welcome.
  • · Replies 25 ·
  • · Replies 18 ·
