Magnetic field induced by current in a conductor question
This discussion focuses on Lenz's Law as it relates to alternating current (A.C.) generators. It establishes that when the north pole of a magnet approaches a conductor in a stator, the induced current generates a magnetic field that opposes the change, effectively turning that section of the stator into a south pole. This interaction creates drag due to the repulsive field when the magnet approaches and an attractive field when it moves away. Additionally, the electromagnetic torque produced is directly proportional to the sine of the angle (ø) between the rotating fields of the stator and rotor, emphasizing that the induced field cannot align perfectly or oppose the original field.
  • Understanding of Lenz's Law
  • Knowledge of alternating current (A.C.) generators
  • Familiarity with electromagnetic torque concepts
  • Basic principles of magnetic fields and poles
  • Study the mathematical derivation of Lenz's Law in electromagnetic systems
  • Explore the design and operation of A.C. generators
  • Learn about the relationship between torque and angular displacement in electric machines
  • Investigate the effects of magnetic field interactions in various conductor configurations
Electrical engineers, physics students, and anyone interested in the principles of electromagnetism and A.C. generator functionality.
jearls74
I am trying to understand Lenz law as it applies to an A.C. generator, Lenz law says " an induced current is always in such a direction as to oppose the motion or change causing it". Does this mean that if the north pole of a magnet passes a conductor in a stator, that the current induced in the the conductor will cause that section of the stator perpendicular to the north pole of the magnet to become a south pole magnet? and is this magnetic attraction what causes drag?
When the magnet is approaching the induced current will produce a repulsive field, and when it is moving away then the field will be attractive. So approaching will produce the same kind of pole and moving away the opposite pole.
Consequent electromagnetic torque is proportional with sin(ø),which ø is space difference angle between rotating field of stator and rotating field of rotor, therefore induced field pole cannot be same (ø=0) or opposite (ø=180˚) pole of field that originate induced currents.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
  • · Replies 16 ·
