Rotation of coordinate system mistake or paradox?
The discussion revolves around the mathematical relationships between different coordinate systems in the context of computer graphics, specifically focusing on the rotation of these systems and the implications for vector representation and transformation. Participants explore the equations relating the bases of these coordinate systems and the connections between points represented in them.
  • One participant presents a series of equations relating three coordinate systems (CSA1, CSA2, CSA3) and expresses confusion over an apparent contradiction in the relationships derived from these equations.
  • Another participant suggests that the confusion arises from mixing rotation and transformation concepts, emphasizing the importance of representing vectors as column vectors and the chaining of rotation matrices.
  • Some participants point out a potential typo in the original equations, questioning the direction of the rotation matrix application.
  • There is a discussion about the distinction between rotation (which physically alters a vector) and transformation (which changes how a vector is represented in different coordinate systems), with a claim that one is the transpose of the other.
  • A later reply clarifies the interpretation of the equations, indicating that the basis vectors of one frame as represented in another frame were misidentified in the original equations.
Participants generally agree that there is confusion regarding the distinction between rotation and transformation, but there is no consensus on the correct interpretation of the equations presented. Multiple viewpoints on the nature of the mistake remain unresolved.
Limitations in the discussion include potential misunderstandings of the relationship between rotation matrices and transformation matrices, as well as the representation of vectors in different coordinate systems. The discussion does not resolve these complexities.
zokos
Hello to all,
I am currently studying computer graphics and I have came up with the following problem. Consider that we have three coordinate systems, let's say CSA1, CSA2 and CSA3 that have the same origin and differ by a rotation. That is to CSA2 connects to CSA1 by R12 and CSA3 to CSA1 by R13. Assume that Ai represents a base for the corresponding coordinate system CSAi. That is Ai comprises from 3 unit orthogonal vectors that are the base of CSAi. Then A2 connects to A1 via:
A2=R12*A1 (eq. 1)
and moreover
A3=R13*A1 (eq. 2)
eq. 1 becomes A1=inv(R12) * A2 (eq. 3) (inv stands for inverse) and eq. 2 using eq. 3 becomes
A3=R13*inv(R12)*A2 (eq. 4)
now we also know from theory that the coordinates (P1, P2, P3) of a point P in the three coordinates systems are connected via:
P2=inv(R12)*P1 (eq. 5)
P3=inv(R13)*P1 (eq. 6)
eq. 5 becomes P1=R12*P2 and substituting it in eq. 6 we have that
P3=inv(R13)*R12*P2 (eq. 7)
moreover applying the same rule in eq. 4, we get that the coordinates of P in the second and third coordinate system are connected via:
P3=inv(R13*inv(R12))*P2 that is
P3=R12*inv(R13)*P2 (eq. 8)
equations 7 and 8 gives us that
inv(R13)*R12=R12*inv(R13)
which is obviously wrong.
can anyone help me and show me my mistake?
Many thx,
zokos
Your equations (5) to (7) are fine -- so long as you are representing vectors as column vectors. What's happening is that you are mixing up rotation and transformation in equations (1) to (4).
I tried to write up a more verbose explanation, but it just got too danged long. So, the short answer: With vectors represented as column vectors, rotation matrices chain left to right. That is,
[tex]R_{2\to 3} = R_{2\to 1}\,R_{1\to 3} = R_{1\to 2}^{\,-1}\,R_{1\to 3}[/tex]
Transformation matrices chain left to right:
[tex]T_{2\to 3} = T_{1\to 3}\,T_{2\to 1} = T_{1\to 3}\,T_{1\to 2}^{\,-1}[/tex]
To understand why, it really helps to understand the difference between vectors and covectors.
I followed your argument up to here:
A2=R12*A1 (eq. 1)
Maybe you made a typo, but you stated R12 was the rotation that brought CSA2 to CSA1. But you multiply R12 by A1. It ought to be the reverse:
A1=R12*A2 (eq. 1)
No, he did it right, kind of. You, too, are confusing rotation and transformation.
  • Rotation physically rotates some object by some angle. Rotating a vector results in a vector that is physically distinct from the original.
  • Transformation deals with the representation of the same vector in two different coordinate systems. Here the vector itself doesn't change. What does change is how the vector is represented. For example, the position of object B with respect to object A can be represented in a slew of different coordinate systems. All of those representations are representations of the same thing, the vector from A to B.
Transformation and rotation are related concepts. The rotation matrix that physically rotates the basis vectors from frame 1 to frame 2 is closely allied with the transformation matrix that transforms the representation of a vector in frame 1 to the representation in frame 2. One is the transpose of the other.
first of all, thanks for the reply. I am sure the problem is, like you point out, in the confusion of transformation and rotation but I don't really get what is my mistake in equations 1-4. In my notes it states that if the transformation matrix for two coordinate frames is T then its inverse is the corresponding rotation matrix, which I think is consistent with what I wrote.
I have read in the past about covariance and contravariance so if you don't have time to explain further could you give me any explanatory links.
Anyway, i am much obliged
zokos
The problem is your equations (1) to (3) -- and your interpretation of them.
What your equation (1) is really saying is that the basis vectors of frame 2 as represented in frame 1 are given by
[tex]e^2_1 = R_{1 \to 2} ^1e_1[/tex]
What your equation (2) is really saying is that the basis vectors of frame 3 as represented in frame 1 are given by
[tex]e^3_1 = R_{1 \to 3} ^1e_1[/tex]
Finally, what your equation (3) is really saying is that the basis vectors of frame 1 as represented in frame 2 are given by
[tex]e^1_2 = R^{\;-1}_{1 \to 2} ^2e_2[/tex]
You used A1 in lieu of my [itex]e^1_1[/itex] in your equations 1 and 2, and A1 in lieu of my [itex]e^2_1[/itex] in your equation 3. Those are two different vectors, but you treated them as one and the same.
  • · Replies 178 ·
11K
  • · Replies 55 ·
