Find Range of k for Two Positive Roots of Equation
The discussion revolves around finding the range of the parameter k in the equation 100^x - 10^(x+1) + k = 0, specifically to ensure that the equation has two distinct positive roots. The subject area includes algebra and the properties of quadratic equations.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants explore the implications of the equation's roots and how they relate to the parameter k. There are attempts to derive conditions for k based on the quadratic form of the equation. Questions arise about the distinction between real and positive roots, and how the choice of substitution affects the analysis.
The discussion is active, with participants questioning each other's reasoning and clarifying the requirements for positive roots. Some guidance has been offered regarding the implications of the substitution used in the quadratic equation, and the need to consider the conditions for positive values of k.
There is a noted confusion regarding the interpretation of "two distinct positive roots" versus "two distinct real roots," and participants are examining the constraints imposed by the problem's requirements.
thereddevils
Find the range of the number k so that the equation 100^x-10^(x+1)+k=0 has two distinct positive roots
I know if it says for two distinct roots only , k<25
but now its two distinct POSITIVE roots , so how ?
(sorry wrong, i blatantly answer without reading the question ;P)
One way to solve this problem is to find the generic solutions and then find the range of k that makes both solutions positive.
How did you arrive at k<25? You must have done some work on this problem to arrive at that value. Show it.
ok .
10^(2x)-10^x . 10 + k=0
Let 10^x be b
b^2-10b+k=0
Then since it says two +ve distinct roots ,
b^2-4ac>0 , which is how i found k<25
but the answer given is 0<k<25
I don see where is the 0 coming , i know its sth to do with the word positive .
thereddevils said:
ok .
Let 10^x be b
b^2-10b+k=0
Ok so far, but your choice of b here is going to get you in trouble. Something like u would have been a much better choice:
[tex]\aligned<br /> &10^{2x} - 10\,10^x + k = 0 \ \Rightarrow \\<br /> &u^2 - 10u + k = 0 \qquad \text{with the substitution}\ u \equiv 10^x<br /> \endaligned[/tex]
This is where the choice of b will get you in trouble. This b is not the same as your variable b.
Regarding the problem itself: Are you supposed to find the range of k that yields two distinct real solutions for x, or the range that yields two positive solutions?Hint: with u=10x, what values for u correspond to a real value for x? To a positive value of x?
ok ,
u^2 - 10u + k = 0
then b^2-4ac>0
(-10)^2-4k>0
100-4k>0
k<25 , still i get the same thing .
And this range of values of k is supposed two distinct , positive and real solution . Is it possible ?
You are too hung up on the range.
Some questions,
  • What are the solutions in terms of u?
    This is a simple quadratic equation.
  • What is x in terms of u?
    Forget about the quadratic equation in answering this question. All that matters is that u=10x.
  • How do these solutions for u translate to solutions for x?
    Use the above.
  • Does the answer to the above question always make sense?
    Just because there are two real solutions for u does not necessarily mean these translate to two real solutions for x.
  • What is the range of u that yields positive values for x?
    Once again forget about the quadratic equation in answering this question.
  • What does that translate to in terms of k[/]?
Some questions,
    Use the above.
thanks ! Or maybe i can also do it this way ,
since i make the substitution u=10^x , u>0
u^2-10u+k=0
so k>0 -- 1
Then since it has two distinct roots , b^2-4ac>0 which implies k<25 ---2
so combining 1 and 2
0<k<25
No what about two positive roots, or was a misstatement in the original post?
  • · Replies 22 ·
  • · Replies 46 ·
  • · Replies 27 ·
