Solved: Computing Potential Inside a Resistor Filled with Inhomogeneous Material
  • Thread starter Thread starter likephysics
    Potential Scalar
The discussion revolves around computing the electric potential inside a cylindrical resistor filled with an inhomogeneous material characterized by a z-dependent electrical conductivity σ(z). The setup involves applying a static voltage to the ends of the cylinder, which is capped by materials of infinite conductivity.
  • Participants explore the application of Poisson's equation in cylindrical coordinates, questioning the necessity of charge density ρ and its implications for using Laplace's equation.
  • Some suggest breaking down the cylinder into slices to analyze current flow and potential differences, while others question the assumptions regarding charge density and uniformity of current density.
  • There are discussions about integrating expressions for current density and potential, with some participants attempting to clarify the roles of constants in the equations.
The conversation is ongoing, with participants providing various insights and suggestions for approaching the problem. Some guidance has been offered regarding the treatment of the cylinder as a series of resistive slices, and there is an exploration of boundary conditions and charge densities. However, there is no explicit consensus on the correct approach or final formulation.
Participants note the lack of specific boundary conditions and question the assumptions made about charge density within the material. There is also mention of potential confusion regarding the constants used in the equations.
likephysics
π²³ ∞ ° → ~ µ ρ σ τ ω ∑ … √ ∫ ≤ ≥ ± ∃ · θ φ ψ Ω α β γ δ ∂ ∆ ∇ ε λ Λ Γ ô
Consider the cylindrical in free space as shown below. The resistor has diameter 2a, length l, is filled with a inhomogeneous material with a z dependent electrical conductivity σ(z) and is capped by 2 thin disks of materials with infinite conductivity. A static voltage φ0 is applied to the 2 disks with a battery.
Show that the potential inside the battery is given by
φ (z)= ∫ (C1/σ(z)) dz+ C2
C1,C2 are constants
I am trying to use poisson's equation in cylindrical coordinates.
But I am not sure, how to get the right hand side
The potential varies only along Z and is constant along r and φ
Therefore, poissons eqn will reduce to
d2(φ)/dz2 = -ρ/ε
I need σ(z) on the right hand side, but I have ρ/ε. How do I arrive at σ(z)?
Poisson's Equation is not the way to go. The cylinder is neutral (ρ=0) as current I flows through it.
Slice the cylinder up like salami and consider a single slice. It has thickness dz, conductivity σ(z), area A and potential difference dV across it. Find an expression for the current I through it. Note that this current is the same for all the slices, i.e. the expression you have is a constant. Call that constant C1. You get my drift?
Kuruman, why is ρ=0. Can you explain please.
Also, if ρ=0 then I can use Laplace equation.
Since kuruman not likely to post, I think you should consider his suggestion. Find dV for a crosssection and add them up with the integral.
There's no reason I can think of to look for pattern fitting to Laplace's equation. φ(z) = ∫(C1/σ(z))dz + C2 is not second order in anything. The voltage is Static, for one. The C1 and C2 in the equation are constants, not capacitance if that's what's causing confusion.
oh,
dv = E.dz
But E = J/σ(z)
v = ∫J/σ(z) dz + C2
Here, C1=J
This is it?
I didn't mean to imply C1,C2 as capacitance. I know they are constants. I thought you integrate once, you get C1 and do it again, you get C2.
I think you're supposed to assume that the current density inside the battery is uniform.That means that at any given time, the amount of charge leaving some region in the conductor will be the same as the amount of current entering the region. Therefor, there will be no charge buildup and you can assume the charge density is zero.[/quote]
You would need appropriate boundary conditions, which you don't have.
likephysics said:
This is it?
Not really. The resistance of a slice is
R = dz/σA (A = cross sectional area)
I = dV/R = σA (dV/dz) = constant
Take it from here. It's a generalized "resistors in series" problem.
Ok. I get it now.
There's another question in the same problem.
If σ is constant, determine potential φ inside the resistor, current density J, surface and volume charge densities.
How do I find the surface and volume charge densities?
I thought they were zero.
I tried to apply the boundary conditions at the surface(r=a), E field is in the opposite direction of V, in the +z direction. So there's only transverse component. No normal component. Hence no surface charge. Is this right?
I have no idea how to find the volume charge density. QxVolume of the cylinder?
Did you do the integral to find V(z)? What does Poisson's Equation say?
Well, I get C1z+C2=ρ/ε
This is not correct. How exactly did you get the left side of the equation? Please show your work.
