Applying Kirchoff's Law to a Short-Circuited Resistor: Where Is the Fallacy?
The discussion revolves around the application of Kirchhoff's laws to a circuit with a short-circuited resistor. Participants explore the implications of assuming zero resistance in certain branches of the circuit and the resulting ambiguities in applying Kirchhoff's loop law.
  • One participant presents a circuit diagram and claims that applying Kirchhoff's loop law leads to contradictory results, questioning where the fallacy lies.
  • Another participant suggests that assuming zero resistance in certain branches may lead to infinite current, which complicates the application of Kirchhoff's laws.
  • A different participant argues that Kirchhoff's laws can be applied in ideal situations, prompting further debate about the nature of ideal versus real circuits.
  • One participant explains that when points in a circuit are connected by a wire (short), they are at the same potential, which affects the application of Kirchhoff's voltage law.
  • Another participant emphasizes that the potential difference across a pure conductor is zero, reinforcing the idea that the current through the shorted resistor is also zero.
  • Some participants express a desire for a rigorous proof of the loop law, indicating a need for deeper understanding of its foundations.
Participants express differing views on the applicability of Kirchhoff's laws in ideal versus non-ideal situations. There is no consensus on the correct interpretation of the circuit or the application of the laws, leading to ongoing debate and unresolved questions.
Participants highlight the limitations of applying Kirchhoff's laws in scenarios involving zero resistance and infinite current, but do not resolve the ambiguities presented in the initial claims.
saubhik
In the attachment (also given at bottom for your convenience) you can see the circuit diagram. We all know that the 5 ohm resistor is short-circuited so no current flows through the resistor. But if we apply Kirchoff's loop law with the following symbols:
i = current through DBAC from positive terminal of battery
i1 = current through CD from junction C
i-i1 = current through CEFD from E​
we get,
from loop AEFBA,
5(i-i1) = 5 or i-i1 = 1​
from loop CEFDC,
5(i-i1) = 0 or i-i1 = 0​
Thus ambiguity arises.
Can anyone please explain me where I am going wrong ?
Also if we apply loop law to BDCAB,
5 = 0​
Where is the fallacy here? (i mean, where am i wrong ? )
Thank you.
[PLAIN]http://img594.imageshack.us/img594/7609/circuit.jpg
Hi saubhik! :wink:
Your diagram assumes that DBAC and CD both have zero resistance.
I think if you put in an actual small resistance (say 10-6), then everything will be ok. :smile:
Thnx tiny-tim for the fast reply:approve:
But assuming that DBAC and CD both have zero resistance, can't we apply Kirchoff's laws. (in fact that's what we do in our regular exercises?)
So, you mean kirchhoffs laws not applicable for ideal situations?
uhhh? :redface: what's ideal about zero resistance and infinite current? :confused:
No, you can't apply Kirchhoff (two h's :wink:) if any part of the circuit would have infinite current. :smile:
can anyone tell me about the origin of loop law or may be its proof?
I kind of meant "abstract" situations referring to zero resistance and infinite current :biggrin:
By physical reasonings can you prove the loop law?
Work done = charge times potential difference.
So the total potential difference round a loop has to equal zero (if it didn't, you could move a charge all the way round the circuit and extract work :wink:).
And potential difference for a resistance happens to be IR (there are diffferent formulas for other devices).
The fallacy is that you are not applying Kirchoffs voltage law correctly. When two points are at the same potential because they are connected by a wire (short ) they are the same point for the purposes of KVL.
If you look at you diagram Points A, B, C, D, E and F are all connected by a wire or short and are therefore at the same potential and are therefore part of the same point. This is no different form a point midway between say C and E which can be considered as part of C or E.
Since all points are really pat of one large 'superpoint' you do not have even one loop to apply KVL to.
What this is telling you is that by introducing the short you have the same situation as if you had one terminal only and connected both ends of your resistor and battery to it.
i beg to disagree with tiny tim,loop law is for the ideal situation(what u n i have learnt),
so if u want to prove it rigorously, no I am not giving full solutions(it'll kill me) to you conserve energy through different paths or more OBVIOUSLY start by saying that "a point in any circuit is at zero potential differnce with respect to itself thus extend this statement to a "loop" in the circuit(thats why you add up PD in any random order specifying that at the end of it its going to be zero, now try to get this on paper and see the "miracle happen"
hope i could help
vaibhav.
oh by the way if you haven't noticed PD across a pure conducter, saubhik is zero, hence the resistance is shorted out(PD across it also zero, if you try looking through it via current law) hencethe current through resistance is also ZERO.
problem solved..:P
can't believe everyone except 2 people here didnt notice that..:)
in case you are correct, then where am I wrong in my application of loop law on the above circuit diagram (in which i m getting ambiguous answers?)
look one thread above yours I've posted 2 threads, one explanation one answer.
  • · Replies 38 ·
