How many LED's are in a typical LED monitor?
  • Thread starter Thread starter patjk
    Led Monitor
The discussion centers around the number of LEDs in typical LED monitors, particularly comparing different sizes such as 20-inch and 24-inch models. Participants explore the role of LEDs in backlighting, the functioning of pixels in LCD monitors, and the differences between various display technologies, including OLEDs.
  • One participant inquires about the number of LEDs in different sizes of LED monitors.
  • Another participant clarifies that LEDs serve as backlights rather than individual pixels, mentioning two arrangements: a grid of several hundred LEDs or a line of a few dozen along the edges.
  • Questions arise regarding how colors are produced in LED monitors, with a participant explaining the use of colored filters and LCD shutters in individual pixels.
  • Further inquiries are made about whether LED monitors use the same setup as LCDs and if a single pixel can display more than one color.
  • Participants discuss the efficiency and longevity of LEDs compared to fluorescent lamps as backlighting sources.
  • There is mention of purely LED display screens used in large outdoor settings, which utilize groups of LEDs for color display.
  • One participant asks how computers control the color displayed on screens, leading to an explanation of voltage control over LCDs.
  • Organic LED displays (OLEDs) are introduced, noting that each pixel consists of multiple LEDs for color display, but their market presence is questioned.
  • Local dimming techniques in newer LED-LCDs are mentioned, which enhance contrast ratios by selectively turning off backlighting.
Participants express varying views on the specifics of LED monitor technology, including the role of LEDs, pixel color production, and the differences between display types. No consensus is reached on the exact number of LEDs in monitors or the effectiveness of different technologies.
Some statements depend on specific definitions of LED monitors and may not account for variations in technology across different models or manufacturers. The discussion includes assumptions about the capabilities of pixels and the efficiency of backlighting methods.
This discussion may be of interest to individuals exploring display technology, including students, hobbyists, and professionals in electronics or computer science fields.
patjk
How many LED's are in a typical LED monitor? For example, how many in a 20in vs. in a 24in, etc?
Thanks
LEDs are only used as a backlight, not as individual pixels.
There are two arrangments - a grid of several hundred LEDs in the back of the TV and for thinner units a line of a few dozen LEDs along the edges.
Great, thanks.
What in a LED monitor causes the colors to appear?
Cheers.
In an LCD monitor individual pixels are covered with a red/green or blue coloured filter made of plastic. Each pixel contains an LCD shutter which either let's through or blocks the white light from the white LEDs in the back. An individual pixel then gives a red/green or blue point.
Plasma TVs are similar except that each pixel glows white, rather than needing a backlight, the color is still set by the filter in front.
Great info, thanks.
Do LED monitors use the same type of setup as an LCD (as you discussed above)?
For LCD, can 1 pixel put out more than 1 color (like a gradient for example. I assume not, but curious if so)? And how are each pixel lit (what provides the light source, is it just a small bulb?)?
For an LCD TV the backlight LED gives you the ligth source - the only reason for using LEDs rather than flourescent lamps is the smaller size, greater efficency and longer life.
A single pixel only puts out one color (red,gree or blue) groups of three or four pixels are used to give all the colors by varying amounts of these primary colors.
ps .There are purely LED display screens used for large outdoors screen such as in stadiums - these do use groups of LEDs in each pixel to give either a red, green or blue light.
How does the computer trigger what color needs to be shown in which location at any given time?
You set a voltage on a line that turns on or off the LCD to allow light through or not. You can control the brightness by turning the LCD on/off quickly and varying the relative amount of on-off time.
see http://en.wikipedia.org/wiki/Liquid_crystal_display
There are also Organic LED displays in which every pixel actually *is* an OLED (okay, 3--one each for red, green and blue in the colour displays and one in the monochrome ones).
http://en.wikipedia.org/wiki/Organic_LED
While I've heard of them in small cellphones and handheld devices, and the Wikipedia article mentions that there is at least one commercial OLED TV, I don't think they've really taken off (or at least, not yet).
mgb_phys said:
the only reason for using LEDs rather than flourescent lamps is the smaller size, greater efficency and longer life..
Also note that some of the newer/more expensive LED-LCD employ a technique called local dimming, where certain of the backlighting is turned off so darker blacks and higher contrast ratios can be displayed. Note that the vast majority do not though.
  • · Replies 53 ·
9K
12K
  • · Replies 17 ·
