Conditional expectation on multiple variables
The discussion focuses on computing the conditional expectation E[X|Y1,Y2] for discrete random variables. The formula E[X|Y1,Y2] = ∑_x{x p(x|y1,y2)} is confirmed as correct, where p(x|y1,y2) = p(x ∩ y1 ∩ y2) / p(y1 ∩ y2). When Y1 and Y2 are independent and identically distributed (iid), the joint probability simplifies to p(y1, y2) = p(y1)p(y2). The expected value is calculated using summation for discrete variables and integration for continuous variables, with results dependent on both Y1 and Y2.
  • Understanding of conditional probability and joint distributions
  • Familiarity with discrete and continuous random variables
  • Knowledge of probability mass functions and density functions
  • Basic calculus for integration in continuous cases
  • Study the properties of independent and identically distributed (iid) random variables
  • Learn about joint probability distributions and their applications
  • Explore the concept of marginal probability distributions
  • Investigate the use of the Law of Total Expectation in probability theory
Statisticians, data scientists, and anyone involved in probability theory or statistical modeling who needs to compute conditional expectations involving multiple variables.
dabd
How to compute [tex]E[X|Y1,Y2][/tex]?
Assume all random variables are discrete.
I tried [tex]E[X|Y1,Y2] = \sum_x{x p(x|y1,y2)[/tex] but I'm not sure how to compute [tex]p(x|y1,y2] = \frac{p(x \cap y1 \cap y2)}{p(y1 \cap y2)}[/tex]
If it is correct, how can I simplify the expression if Y1 and Y2 are iid?
If y1 and y2 are independent then p(y1, y2) = p(y1)p(y2).
In general
[tex] p(x \mid y_1, y_2) = \frac{p(x,y_1,y_2)}{p(y_1,y_2)}[/tex]
where the numerator is the joint density (or mass function for discrete case) of all three, and the denominator is the marginal of the two ys. You treat this as a function of [itex]x[/itex] alone. Then, in the discrete case, the expected value is
[tex] \sum x p(x \mid y_1, y_2)[/tex]
and in the continuous case it is
[tex] \int x p(x \mid y_1, y_2) \, dx[/tex]
In each case it is possible for the answer to depend on both [itex]y_1, y_2[/itex].
