Area of one cylinder inside another intersecting cylinder
  • Thread starter Thread starter symmetric
    Area Cylinder
The discussion revolves around finding the surface area of a part of a cylinder defined by the equation x² + z² = a², which is situated inside another cylinder described by x² + y² = 2ay, and is constrained to the positive octant (x ≥ 0, y ≥ 0, z ≥ 0). The parameter a is assumed to be greater than zero.
  • Participants discuss the parametrization of the surface and the limits of integration for calculating the area. There is a focus on the correct interpretation of the bounds for y in relation to x, and some participants suggest changing the order of integration. Others question the assumptions made regarding the parameter a and its implications on the problem setup.
Some participants have provided corrections to the original setup, leading to a revised area integral that aligns with the expected answer of 2a². There is acknowledgment of previous mistakes and a collaborative effort to clarify the problem, with multiple methods being explored for verification.
There are discussions about the constraints of the problem, particularly regarding the assumptions about the parameter a, and how these affect the integration limits and the overall approach to finding the surface area.
symmetric
1. Homework Statement :
Find surface area of part of cylinder [itex]x^2 + z^2 = 1[/itex] that is inside the cylinder [itex]x^2 + y^2 = 2ay[/itex] and also in the positive octant ( [itex]x \geq 0, y \geq 0, z \geq 0[/itex] ). Assume a > 0.
[tex]x^2 + z^2 = 1[/tex]
[tex]x^2 + y^2 = 2ay[/tex]
a > 0
Cylinder expression [itex]x^2 + z^2 = 1[/itex] can be written as [itex]z = \sqrt{ ( a^2 - x^2 ) }[/itex].This surface can be projected on X-Y plane by using following parametrization -
x = x
y = y
z = f( x, y ) = [itex]\sqrt{ a^2 - x^2 }[/itex]
Hence the surface area of cylinder [itex]x^2 + z^2 = 1[/itex] for above parametrization is given by integral -
Area integral = [itex]\iint{\sqrt{ ( 1 + f'_{x})^2 + ( f'_{y})^2 }} dx dy[/itex]
Now, [itex]\sqrt{ 1 + (f'_{x})^2 + ( f'_{y})^2 }[/itex] = [itex]\sqrt{ 1 + \frac{x^2}{a^2 - x^2} + 0 }[/itex] = [itex]\frac{a}{ \sqrt{ a^2 - x^2 }}[/itex]
Area integral = [itex]\iint{ \frac{a}{ \sqrt{ a^2 - x^2 }}} dx dy[/itex]
The limits of this integral will be decided by second insecting cylinder [itex]x^2 + y^2 = 2ay[/itex]
Working out for finding limits -
[itex]y^2 + (-2a) y + x^2 = 0[/itex] treating second order equation in ' y ' we can write -
[itex]y = a \pm \sqrt { a^2 - x^2 }[/itex] selecting positive root for given conditions for positive octant.
Hence limits are – for x -> 0 to a and for y -> 0 to [itex]a + \sqrt { a^2 - x^2 }[/itex]
The integral becomes
Area integral = [itex]\int_{x = 0}^{ x = a } \int_{ y = 0 }^{ y = a + \sqrt { a^2 - x^2 } }\frac{a}{ \sqrt{ a^2 - x^2 }} dy dx[/itex]
= [itex]\int_{0}^{a} \frac{ a ( a + \sqrt { a^2 - x^2 } )}{ \sqrt { a^2 - x^2 }} dx[/itex]
= [itex]a^2 \int_{0}^{a} \frac{ dx }{ \sqrt { a^2 - x^2 } } + a \int_{0}^{a}} dx[/itex]
= [itex]a^2 \left[ \arcsin \left ( \frac{x}{a} \right) \right]_{0}^{a} + a^2[/itex]
Required area = [itex]a^2 \left[ \frac{\pi}{2} +1 \right][/itex]
The answer given in the book is [itex]2a^2[/itex] . Am I going wrong somewhere ? Please help.
a > 0
x = x
y = y
shouldn't
[tex]z = f( x, y ) = \sqrt{ 1 - x^2 }[/tex]?
also you need to assume a < 1, which you're doing, but should be aware of
otherwise i think your mothod is ok ;)
@lanedance - Thanks for your reply.
You have pointed out correct typing mistake due to some 'copy paste'. Sorry for that.
Corrected problem is as follows -
Find surface area of part of cylinder [itex]x^2 + z^2 = a^2[/itex] that is inside the cylinder [itex]x^2 + y^2 = 2ay[/itex] and also in the positive octant ( [itex]x \geq 0, y \geq 0, z \geq 0[/itex] ). Assume a > 0.
[tex]x^2 + z^2 = a^2[/tex]
a > 0
Cylinder expression [itex]x^2 + z^2 = a^2[/itex] can be written as [itex]z = \sqrt{ ( a^2 - x^2 ) }[/itex].This surface can be projected on X-Y plane by using following parametrization -
x = x
y = y
Hence the surface area of cylinder [itex]x^2 + z^2 = a^2[/itex] for above parametrization is given by integral -
= [itex]a^2 \int_{0}^{a} \frac{ dx }{ \sqrt { a^2 - x^2 } } + a \int_{0}^{a} dx[/itex]
ok so i had another look & i think your lower limit for the y integration step is incorrect, it should also be dependent on x.
it may help to change the integration order, do x then y.
to help see it, the vertical cylinder given the bounds is defined by the circle
[tex]x^2 + (y-a)^2 = a^2[/tex]
so radius a, centred on (0,a)
@lanedance
You are right. After analyzing the problem again, posting the corrected area integral -
Area integral = [tex]\int_{x = 0}^{ x = a } \int_{ y = a - \sqrt { a^2 - x^2 } }^{ y = a + \sqrt { a^2 - x^2 } }\frac{a}{ \sqrt{ a^2 - x^2 }} dy dx[/tex]
= [tex]\int_{0}^{a} \frac{ a ( a + \sqrt { a^2 - x^2 } - a + \sqrt { a^2 - x^2 }) }{ \sqrt { a^2 - x^2 }} dx[/tex]
= [tex]2a \int_{0}^{a} dx[/tex]
Required area = [tex]2a^2[/tex]
Which is same as required !
Above problem solved in cylindrical parametrization is posted here -
http://www.cramster.com/answers-may-10/calculus/solved-but-answer-not-problem-statement-find-the-surface-area-of-that-part-of_854407.aspx
In addition to above two methods I have also tried above problem using Green's method given here -
http://mathworld.wolfram.com/SteinmetzSolid.html
( answer by Green's Theorem method is posted in my next post )
I just want confirm that, everything is solved correctly, and steps are appropriate for above three methods.
Method III - Using Green's theorem
Given equation [itex]x^2 + z^2 = a^2[/itex] can be parametrized as follows -
x = x
z = [itex]\sqrt{ a^2 - x^2 }[/itex]
According to result obtained from Green's theorem we can write -
Area = [itex]\int{ y ds }[/itex]
where ds = [tex]\sqrt{ 1 + \left(\frac{dz}{dx} \right )^2 } dx[/tex]
ds = [tex]\frac{a}{\sqrt{ a^2 - x^2 } } dx[/tex]
Now, y can be calculated from cylinder equation [itex]x^2 + y^2 = 2ay[/itex] as
[itex]y = a \pm \sqrt{ a^2 - x^2 }[/itex]
Here we have mapped required surface area on x-y plane. Mapped area region is divided into two regions for which y takes two different values calculated. Hence, required area is given by -
Area = [tex]\left( \int_{x = 0}^{ x = a }\frac{a( a + \sqrt{ a^2 - x^2 } ) dx } {\sqrt{ a^2 - x^2 }}\right) - \left( \int_{x = 0}^{ x = a }\frac{a( a - \sqrt{ a^2 - x^2 } ) dx } {\sqrt{ a^2 - x^2 }}\right)[/tex]
Negative sign of second integral indicates opposite orientation of second part of surface.
Area = [itex]2a \int_{0}^{a} dx[/itex]
Area = [itex]2a^2[/itex]
Corrections and suggestions will be highly appreciated.
