Thread Closed
Why do ice skaters bend at an angle when taking a turn at high speed?
Share Thread Thread Tools
May20-10, 02:29 PM   #1
I saw some pictures of ice skaters leaning while taking turn.....in case of motorcyclists it is due to gyro effect but what in this case?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
May20-10, 03:50 PM   #2
Recognitions:
It is essentially the same effect. It is necessary to counteract inertia, which would tend to keep them going straight.
May20-10, 04:05 PM   #3
is there any analysis of this effect (as that of gyro there exists based on angular momentum, active reactive couple) ?
Why they would lean? Inertia would still throw them forward while turning theorotically!
May20-10, 04:17 PM   #4
Intertia "throws" them toward the outside of the curve.
May20-10, 05:23 PM   #5
Recognitions:
Homework Helper Homework Help
Leaning is done so that the outwards roll torque related to centrepital force is countered by an inwards roll torque related to gravity.
Lean angle (from vertical) θ = tan-1(v2 / (g r) ).
This is unrelated to any gyroscopic effect. You could replace the wheels and tires of a bicycle with rounded skate bladed and be able to glide and steer on ice conventionally, without any gyroscopic effects.
May21-10, 03:46 AM   #6
Force required for circular motion should be applied on the centre of mass, but for an ice skater it is applied at their base. To avoid spinning outwards they lean in. The effect of this is to move your centre of mass away from vertical with the point of contact with the floor, which provides an opposing torque (the reaction force from the floor no longer coincides with your centre of mass).
If you get the angle right you have circular motion and no net torque.
(Basically what rcgldr said but wordier).
Thread Closed
Thread Tools
Similar Threads for: Why do ice skaters bend at an angle when taking a turn at high speed?
Thread Forum Replies
Mechanics; speed of car travelling around bend. Introductory Physics Homework 1
ice skaters speed of rotation Introductory Physics Homework 7
maximum speed of car round banked bend Introductory Physics Homework 4
High Tc superconductors turn 20! Atomic, Solid State, Comp. Physics 10
Motorcycle: Lean Angle, Speed, and Turn Radius Classical Physics 0
