Electromagnetic force on a particle in two different frames of reference
The discussion revolves around the electromagnetic force experienced by a charged particle in two different frames of reference, particularly focusing on the effects of electrostatic repulsion and magnetic forces in the context of special relativity. Participants explore the implications of relativistic effects on charge density and electric fields, as well as the relationship between magnetism and electrostatics.
  • One participant describes a scenario involving a charged particle near a current-carrying conductor, noting the forces acting on the particle in different frames of reference.
  • Another participant challenges the assertion that the magnitude of the electrostatic repulsive force remains unchanged across frames, introducing the concept of length contraction and its effect on charge density and electric field strength.
  • Some participants propose that magnetism can be derived from electrostatics and relativity, suggesting a deep connection between these concepts as reflected in Maxwell's equations.
  • There is a discussion about the absence of net charge in the conductor and its implications for the Coulomb force, with differing views on the presence of electric fields in various frames.
  • Participants reference external resources to support their arguments and clarify the relationship between electric and magnetic fields under Lorentz transformations.
Participants express differing views on the effects of frame transformations on electric and magnetic forces, with some agreeing on the absence of a transverse electric field in certain frames while others highlight the complexities introduced by relativistic effects. The discussion remains unresolved regarding the implications of these transformations on the forces experienced by the charged particle.
Participants acknowledge the limitations of their arguments, particularly regarding the assumptions made about charge distribution and the applicability of different frames of reference. The discussion includes references to specific equations and external resources that illustrate the complexities of the topic.
McLaren Rulez
Consider an infinitely long straight conductor carrying a current. Let's assume that the free charges in the conductor are positive and are moving at a drift velocity v. Now, consider a particle of charge +q also moving with v in the same direction as the current at a distance r from the conductor.
It faces two separate forces: One due to electrostatic repulsion from the charges in the wire and another because the wire has a magnetic field and a moving particle in a magnetic field experiences a force. The magnetic force points radially towards the wire and electrostatic repulsion points away from the wire.
Now, think of this in a frame which is moving at v in the same direction as the current. In this frame, the conductor no longer has a current; it is now just a straight piece of conductor with charge. The particle is also at rest in this frame. The only force it faces is electrostatic repulsion. The magnitude of this repulsive force does not change. So the two frames predict different answers to what is going to happen to the particle.
Where am I going wrong?
You are going wrong right here:
Due to the relativistic effect of length contraction the charge density is higher and therefore the e-field is higher in the frame where the magnetic field disappears. Here is an interesting and easily readable page describing the relationship between relativity and magnetism.
http://physics.weber.edu/schroeder/mrr/MRRtalk.html
Thanks Dale! I never thought about that.
So essentially, the phenomenon of magnetism is just a consequence of relativity and not a separate thing, is it?
Yes, you can obtain magnetism from electrostatics + relativity. Of course, it is kind of cheating since relativity was, in some sense, a result of Maxwell's equations.
Then again, it's not cheating at all because Maxwell's equations are a result of scientific effort to come up with the best possible description of Nature.
On a deeper level:
The Lorentz transformations were recognized as relevant long before relativistic physics was formulated. The Lorentz transformations are not unique to relativistic physics, in the sense that they embody something that is part of the fabric of Maxwell's equations.
In a sense relativistic physics was anticipated by Maxwell's equations. I find that fascinating. Maxwell's equations were conceived in terms of Newtonian dynamics, yet they anticipate relativistic physics.
Yeah, that sounds reasonable. Whether you start with electrostatics and relativity and derive magnetism or you start with electromagnetism and derive relativity really is a little irrelevant. You wind up with the same description of nature either way.
Even if there is a current in the infinitely long conductor, I don't think there is any net charge in the conductor, so there is no net Coulomb force (to first order).
Bob S
In the frame where there is no E-field that is correct. That is not correct in other frames. See the link I posted earlier, it is a very enjoyable read.
Hi DaleSpam-
We agree that there is no transverse E-field (Coulomb) force in the lab frame. If we transform from the lab frame to the moving frame using the Lorentz transformations given in
http://pdg.lbl.gov/2002/elecrelarpp.pdf
(see third from last equation in the SI column), we get a pure transverse E-field force, as also shown in your referenced link Eqns (1)-(3):
which is an interesting alternative derivation of the Lorentz transformation for γ ≈ 1.
Bob S
  • · Replies 20 ·
