How to calculate the horse power ?
  • Thread starter Thread starter harvi101
    Power
The discussion revolves around calculating the horsepower required for a small hatchback car based on its weight, top speed, aerodynamic drag coefficient, and tire radius. Participants explore various methods for engine sizing and power requirements, including theoretical calculations and practical considerations.
  • One participant asks how to calculate horsepower given the car's weight (950 kg) and top speed (144 km/h), along with other parameters.
  • Another participant suggests that the majority of power at terminal velocity is due to drag, estimating the required power to be about 37 kW (50 hp) for a car with a frontal area of 1.5 m².
  • A participant inquires about sizing the engine for a small hatchback, seeking clarification on what "size" means in this context.
  • One response indicates that while 50 hp might be sufficient for top speed, more power would be needed for acceleration, suggesting around 60 hp for a budget hatchback.
  • A detailed example is provided for calculating engine specifications, including assumptions about brake mean effective pressure (BMEP) and maximum port velocity.
  • Another participant argues that the information provided is insufficient for detailed engine specification, emphasizing the need for additional data such as fuel type and injection method.
  • A participant presents a formula for calculating horsepower based on weight and velocity, yielding a value that seems high for a small car.
  • Discussion includes estimates of power losses due to aerodynamic drag, rolling resistance, and internal resistance, with varying opinions on the accuracy of these estimates.
  • One participant expresses uncertainty about the calculations for aerodynamic drag and other forces, leading to further clarification and corrections from others.
Participants generally agree that aerodynamic drag is a significant factor in determining power requirements, but there are multiple competing views on the specifics of engine sizing, power calculations, and the assumptions made in those calculations. The discussion remains unresolved with differing opinions on the accuracy of various estimates and methods.
Participants note limitations in the data available for calculating BMEP and port velocity, as well as the need for assumptions regarding engine design and operational parameters. There is also mention of potential losses due to transmission efficiency that have not been quantified in detail.
harvi101
how to calculate the horse power ? if the car weights 950 kg and its top speed is 144 km per hour. how can i size the engine from this data aerodynamic drag coffi = 0.65, tyre radius = 0.27m. please help.
how can i size the engine for small hatch back car.
What do you mean by size? If you mean have the power to do what you want then the aboev is your answer. In reality you'd need more to accelerate up to top speed, but 60ish hp seems sensible for a budget end hatchback.
engine size example
required power = 50 kw
A. choose 2 valve wedge/bathtub SI NA 4- stroke combustion chamber
B. bmep : 10 bar (torque peak and this value is assumed ) would be appropriate; also 20% back up
so bmep@power peak = 10/1.2 = 8.33 bar
C. allow Pmax (choose max port velocity) = 75 m/s
for 2 V wedge/bathtub, d/D = 0.45 ( d= valve dia, D= bore)
Mean piston speed, Ps = Pmax(d/D)(d/D)
so Ps = 15.19 m/s which is ok for life
D. Power = 1/4XPbxAxPs
50 = 1/4x8.33xAx15.19
A = 15.81/1000 meter square
E. Choose 4 cylinders each 15.81/(4x1000) = 3.952/1000 meter square =(pie/4)DxD
so D = 0.0709 m or 71 mm
F. choosing a stroke
(i) assume L/D = 1 , so L = 71 mm
Ps = 2 LN/60
N = 15.19x60/(2x0.071) = 6418 rev/min
(ii) assuming Nmax = 5500 rev/ min
therefore L = 15.19x60/(2x5500) = 82.9 mm ; L/D=1.167
compromise : make L = 77 mm and Nmax = 5918 rev/min
therefore Vs = 4x(pie/4)xDxDxL = 1.219 liters
(it might be worth setting to 1.2 or 1.3 liters)
now keeping the above example in mind how can i calculate the engine specification from the given data
Mass of vehicle (without passangers ) = 950 kg
Type of vehicle = small hatch back
drag coff = 0.65
tyre radius = 0.27 m
max velocity = 144 km/h
(i want for cylinder engine with four valves, is there a way to calculate he bmep and port velocity from the given data)
No, that's not even remotely enough to attempt to specify an engine in that kind of detail. All you can specify is that you need 50hp.
To calculate BMEP you'd need to know the displaced volume. Or you'd need to specify a BMEP to find a volume. There is a shed load of data you need to find out the flow at the port.
What is the point of this? Are you ment to be designing a new engine? Where did you get your example from?
Before you even start trying to specify something to that level you need to think about this engine. Is it going to be run on, carbs, multipoint injection, direct injection? What fuel? Is it going to be turbocharged? etc etc
any good method to calculate the power required from engine to achieve the 144 kmph speed
from speed trap method
hp = weight x (velocity/234)x(velocity/234)x(velocity/234)
hp = 117.09844102277 horsepower ( without the passanger weight ) = 87.32 kw which is really high for a small car
its our assignment and this the example given by our teacher
I said earlier.
You need to find the losses (aero drag, rolling resistance, and any internal resistance). I didn't think that you needed this much detail before so I just used the aero drag, which is by far the highest loss.
I also linked to wiki for the power required to travel a specific speed due to aero drag.
thanks xxChrisxx
i'll try to solve it my taking 40 kw as the required power
Owing to the fact that you are using about 10bar as the BMEP, I assume this engine is a naturally aspirated petrol?EDIT: Also note that that power required would be wheel power. You would have to make an estimate/guess of the losses due to the transmission. About 10-15% seems sensible.
So the aero drag indicates about 40 kW. So due to that alone you'd need approximately 47kW produced at the flywheel. Not only that you would need more to acutally accelerate up to that top speed.
At a guess, i'd estimate that that car would need about 55kW to acutally reach 144kph in a sensible time.
yes i have already mentioned it SI NA 4- stroke
but i don't know how he calculated d/D = 0.45 ( d= valve dia, D= bore) in step C.
Ah so you did, just me skim reading again.
And he basically just made that d/D ratio up (it's not acutally calcualted), as it's looks a sensible size for a pent roof combustion chamber.
If you think about it, he specified it's 2 valves per cylinder. Obviously, you can't have 2 huge valves, as they would clash. Nor should you have two tiny valves. What he has said is make each lvavle slighlty smaller than half the dismeter of the bore so they are big, but still have clearence.
Your valves would have to be smaller as you want to use 4 of them. So the d/D ratio would be different.
thanks man 55kw seems ok . at least now i have starting point . i am thinking of taking bmep = 9 bar and port velocity = 70 m/s and three cylinder 2 valve engine with wedge shape.
losses
rolling resistance = 139.80
aero drag = 11403.05
gradient = 342
Total Losses = 11884.55 = 12 kw is it ok
I've no idea how you got to those figures, but the aero drag is way too low. The others look pretty sensible.
this how i calculated the forces
Vehicle Data
Vehicle selected for engine sizing is Small Hatch back
Vehicle type Mass (kg) CdA (m2) rtypre(m) Vmax(Km/h)
Small hatch 950 (unladen) 0.61 0.27 144
Calculations for the payload
Assuming weight of one passenger = 70 kg
Then weight for the 5 passengers = 70 x 5 =350 kg
Assuming cargo volume = 200 liters = 200 kg
Then the total weight of the vehicle = 950+350+200 = 1500 kg
Calculations for the losses
1. Aerodynamic Drag Resistance
Given Cd A = 0.61 m2
ρ = 1.2 kg/m3
FD = ( Cd A ρ V2)/2 = (0.61x1.2x40x40)/2 = 586.6 = 586 N
2. Rolling Resistance
Given fr = 0.015
FR = m g fr = 1500x9.81x0.015 = 220.725 =221 N
3. Gradient Resistance
Given gradient = 36%
Tan θ = 0.36/1 => θ = Tanֿ (0.36/1) = 19.8º
FG = mg Sin θ = 1500x9.81x Sin 19.8o = 4984.528 N = 4985 N
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 23 ·
12K
