Piston diameter size, fricition, mathematical proof
by gloo
Tags: diameter, fricition, mathematical, piston, proof, size
gloo
gloo is offline
#1
May24-10, 10:39 AM
P: 75
I have already asked the question of piston diameter size and efficiency in an earlier thread but i'll recap.
My question was that is it true that the larger diameter piston have a larger propensity to overcome the mechanical loss of fricition due to the piston rings contact with the mating surface inside the piston walls.
The resounding response was yes, but I wanted to clarify 2 factors:
1. Would it matter if the the rings were lubricated by water instead of oil?
2. Would it be correct to express it in a mathematical type proof by using this method:
Circumference formula : pi * 2*radius
Area formula : pi * radius *radius
if we cancel out the constant pi from each equation , we have
circumference forumla : 2 * radius
Area forumla : radius * radius
Thus, for any radius, we can see that the larger the radius, the area formula will have a factor of radius squared, while the circumference formula will only be radius times 2.
Is this a mathematical type of expression we can make to show why larger pistons will be more likely to overcome piston ring friction? The fact that larger radius will have result in a larger area factor relative to the circumference of the piston?
thanks
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
brewnog
brewnog is offline
#2
May24-10, 11:36 AM
Sci Advisor
PF Gold
brewnog's Avatar
P: 2,793
You're nearly there.
The parameter commonly used is volume to surface area ratio. The main source of loss in a combustion chamber isn't due to piston ring friction (which you're correct in saying is a function of circumference) but due to heat loss (which is a function of surface area, both of the piston crown which transfers heat from the combustion gas, of the piston skirts which dissipate heat to the liner and coolant, and of the undercrosn which dissipates heat to the lube oil). Then (and only then!) do you consider ring friction.
I don't know what you mean about using water instead of oil. Theoretically yes, but practically water is hopeless at lubricating, sealing and cleaning engine components.
gloo
gloo is offline
#3
Jun3-10, 01:52 PM
P: 75
My device is not really a piston with gas combustion as much as it is a hydrualic (water) as the main substance being sealed. The device basically works in this manner:
A chamber has an outside water seal and a seal inside. Both these seals are used to seal the passage of water and they are dynamic in nature (like a piston ring). Basically i want the chamber to be moved by water pressure from the water surrounding the chamber. The chamber will move back and forth at low speed past the water seals. The pressure driving the chamber is between 500 to 1000 Kpa. The water seal outside prevents water from passing through between itself and a certain point on the outside of the chamber wall. The water seal inside prevents water from passing between itself and the inside chamber walls.
I figured that a larger chamber with a larger area exposure to the water pressure, even though the circumference of the o ring is also larger, would be more likely to have a tendency to move better b/c proportionately, the larger surface area more than compensates for the larger diameter (o ring friction). Thus for every larger radius chamber, the pressure pushing on the larger surface area of the bottom of the chamber, is proportionately greater than for that of a smaller radius chamber and smaller circumference o ring. Would the math example i used be correct in this scenario then?
thanks
brewnog
brewnog is offline
#4
Jun3-10, 02:30 PM
Sci Advisor
PF Gold
brewnog's Avatar
P: 2,793
Yes. As bore diameter increases, your piston area (upon which your fluid acts) increases as a square; the seal contact area increases linearly.
gloo
gloo is offline
#5
Jun3-10, 03:05 PM
P: 75
Quote Quote by brewnog View Post
Thanks a lot for your help :)
Register to reply
Related Discussions
Fricition: Block on inclined plane Engineering, Comp Sci, & Technology Homework 1
piston size and proportionate forces General Engineering 8
diameter of a planet, known the angular size and distance Biology, Chemistry & Other Homework 1
diameter of the football players' piston? Introductory Physics Homework 4
single piston engine problem - position of piston Introductory Physics Homework 8
