Register to reply
Oil spill: Water pressure VS. oil pressure
by proculation
Tags: buoyancy, oil, pressure, water
Share this thread:
proculation
#1
May30-10, 07:33 PM
P: 71
Hello all,
It's my first post. I'm french canadian so I may make grammar mistakes in English :-)
This is a question I'm asking me since yesterday. It's about the oil spill in the Gulf of Mexico.
The oil and gases are less dense than the salted water. The breach is at about 1500 meters deep. So, by rounding, about 150 atm of pressure.
It's sure the pressure in the underground oil cavity is much more than that. It even blew up the valves and put the rig on fire.
My question is: Does the water pressure at that depth make a difference in the release of the oil ? The quantity ?
If that same oil reserve was discovered at 150m depth and the same accident happened, would it mean the oil would spill ~10 times more since there's less water pressure ?
My instinct would tell me "yes" but i'm wondering about the difference the buoyancy makes.
Thank you,
Olivier Gagnon
Phys.Org News Partner Physics news on Phys.org
Optimum inertial self-propulsion design for snowman-like nanorobot
The Quantum Cheshire Cat: Can neutrons be located at a different place than their own spin?
A transistor-like amplifier for single photons
pallidin
#2
May30-10, 10:42 PM
P: 2,292
Quote Quote by proculation View Post
Sure. The water pressure restricts, to a degree, the amount of the oil release.
proculation
#3
May30-10, 10:50 PM
P: 71
But does it 'compensates' for the buoyancy of the oil at that depth ?
If you put a ball with air at that dept, the force will be very strong to get it to the surface. Is is the same thing for the oil ?
pgardn
#4
May31-10, 11:23 PM
P: 621
I would think if the ball was filled with air at the surface and then moved to 1 mile beneath the ocean you would greatly reduce the density of that ball as it would be smashed a bit assuming you dont fill it with air that has the same surrounding pressure as water at 1 mile deep. This is interesting though as I dont know how much oil can be compressed at higher pressures. Obviously it is much more difficult to compress liquids.
Clearly in this situation not all of the oil/methane is getting to the top. So some chemistry is going on at these high pressures and low temperatures (as reported about the slushy hydrates forming preventing the first "dome" from flowing smoothly). Throw in the dispersants they were using at depth and it gets very complex I would imagine.
I think BP would agree that its complex anyway.
proculation
#5
May31-10, 11:30 PM
P: 71
I'm not talking about the situation but about the physics involved.
The pressure of the water which is about 150 atm and the pressure of the oil well.
My question is quite simple: does that water pressure help to reduce the spill ?
2nd question: with the same oil reserve at 150m (15 atm), would it spill 10 times more ? cetaris paribus.
pgardn
#6
Jun1-10, 12:03 AM
P: 621
Does water pressure help reduce the flow rate? I would imagine it must.
No idea. I was just stating that the density of the oil is going to change. How much I dont know. So when you posted about the buoyant force (3rd post) I reasoned that it was more difficult to reason out. You can cetaris paribus the oil density at 1 mile, while changing the depth and I dont know. I guess someone else can wittle away the enormous number of variables and come up with something.
rcgldr
#7
Jun1-10, 12:13 AM
HW Helper
P: 7,034
The buoyancy effect is minimal compared to the difference in pressure between the oil and the seawater at 5000 feet down. Using the denser (than water) "mud" into the pipe was supposed to increase the pressure opposing the oil pressure (very tall pipe section), but a BP manager decided to fill the last upper section with sea water instead of the denser "mud", which may have contributed to the accident.
proculation
#8
Jun1-10, 12:19 AM
P: 71
Quote Quote by rcgldr View Post
Like I said earlier, the question is not about BP.
It's about the pressures and the quantity of oil spilled variable to the depth of the sea.
pgardn
#9
Jun1-10, 12:23 AM
P: 621
Do you have a link for this?
This is all very sad but at the same time very interesting.
stewartcs
#10
Jun1-10, 10:22 PM
Sci Advisor
stewartcs's Avatar
P: 2,283
The pore pressure of a normal formation is equal to the hydrostatic pressure of water extending from the surface to the subsurface formation of interest. Thus the normal pressure in any area will be equal to the hydrostatic pressure of the water occupying the pore spaces of the formations in that area.
One could certainly argue that since the formation is below the seafloor and the ocean that the pore pressure is greater due to the addition of the seawater hydrostatic head. If the seawater hydrostatic head was not present, then the pore pressure would be reduced thus causing less flow.
However, in the end it works out such that they typically cancel out. That is, the increase in pressure due to the seawater hydrostatic head in the pore pressure is cancelled out by the seawater hydrostatic head at the point of discharge.
CS
notbacktrack
#11
Jun2-10, 12:24 PM
P: 1
Hey dude I just saw your post and I'm getting ready to go to class, not physics unfortunately, but I can do this calculation so just give me until tonight and I should have it up for you.
rcgldr
#12
Jun2-10, 10:24 PM
HW Helper
P: 7,034
Quote Quote by pgardn View Post
A BP employee explained all of this in a 60 minutes episode, 5/30/2010. It's the first (upper left) video on this web page:
http://www.cbs.com/primetime/60_minutes
XLR8
#13
Jun10-10, 01:17 PM
P: 6
I'm unclear about the nature of several of the factors in play here.
First, is the pressure differential between the well and the surrounding seawater the result of the methane coming out of solution in the oil? If this is the case, it would effectively be the equivalent of opening a carbonated beverage - with an initial boil-off of mostly gas followed by a much slower, buoyancy-driven flow.
The physics of this scenario at that depth don't add up though; the water pressure should easily be enough to keep the methane in solution at that depth.
Furthermore, the symptoms don't seem to match; the initial fizz would have happened way back when the well was initially tapped, and most of the methane would have formed bubbles that ascended through the well to create a layer of gas above the layer of oil within the well - meaning the leak would be primarily methane, not oil.
The other possibility is that the pressure differential is just caused by the buoyancy of the oil. If this is the case, there are two possibilities. One is that water is flowing into the well somewhere to fill the void left by the escaping oil. The other is that the rock surrounding the well is physically flexing to push the oil out. If the latter is the correct explanation, that's bad news.
In the scenario involving a fizz-off and the one involving water flowing in, I can think of a bunch of decent sounding solutions. In the final case, I've got nothing.
Clearly, I need to take some geophysics classes, so someone step in an enlighten me here.
rcgldr
#14
Jun10-10, 02:49 PM
HW Helper
P: 7,034
Quote Quote by XLR8 View Post
First, is the pressure differential between the well and the surrounding seawater the result of the methane coming out of solution in the oil? The other possibility is that the pressure differential is just caused by the buoyancy of the oil.
Before the well was drillled, that oil was under very high pressure, unrelated to methane gas content or buoyancy. The drill is housed in a very tall pipe designed to contain the high pressure oil, as well as the "mud" being piped down during the drilling operation.
I assume that the compressability for oil is less than that for water, but not sure. If oil was more compressable, then there could be some depth where compressed oil would have higher density and sink in water.
XLR8
#15
Jun10-10, 03:14 PM
P: 6
The question is why the oil is at higher pressure than the surrounding water and earth. Local pressure differentials don't usually just happen spontaneously. Something caused it.
The deep ocean water is at high pressure too, but if you stuck a water-filled pipe down there you wouldn't create a gusher.
The interesting bit is that the oil comes shooting out even though it has a column of denser stuff sitting on top of it.
So the oil pressure differential relative to water must be due to methane solubility, buoyancy, thermal influences or something along those lines. What I'm looking for is which one we're dealing with.
Andy Resnick
#16
Jun10-10, 03:55 PM
Sci Advisor
P: 5,510
Why does it only have to be one factor? And besides, the properties of crude+methane at depth (and seawater at depth) are not the same as the near-surface situation. Plus, the dispersants used alter the properties of the oil.
Newsweek had a good article recently about 'deep water plumes'. I'm not an expert, but it appears that the oil spurts out of the well and is entrained in the deep water currents- think large planar 'tongues' of fluid- that migrate laterally. The oil concentration is small, but the plumes are several miles in lateral extent and hundreds of feet thick.
http://gulfblog.uga.edu/
http://www.nytimes.com/gwire/2010/06...oil-98517.html
http://www.washingtonpost.com/wp-dyn...060801850.html
Of course, BP claims differently:
http://www.energyboom.com/policy/no-...tists-research
This has some interesting information as well, but nothing quantitative:
www.evs.anl.gov/pub/doc/ProducedWatersWP0401.pdf
XLR8
#17
Jun10-10, 04:17 PM
P: 6
Quote Quote by Andy Resnick View Post
You're right. It doesn't have to be just one factor. Regardless though, I want to understand exactly which factors are at play in causing the pressure build-up within the well.
In my mind, there is good reason to believe that we can rule methane solubility out (see my first post.) If that's the case, then we're down to a few possibilities - some of which could be solvable; such as if water is flowing into the well to fill the void left by the leaked oil (in which case, buoyancy is a contributor to the pressure.)
And you make a good point about dispersants, but unless they're injecting them into the well rather than applying them to plume, they shouldn't affect the dynamics of the inside of the well.
Andy Resnick
#18
Jun10-10, 05:16 PM
Sci Advisor
P: 5,510
According to the Newsweek article, 185,000 gallons of dispersant were pumped directly into the wellhead. 800,000 gallons were applied at the water surface.
And IIRC, the methane is not in a gas phase at depth- it forms hydrates (ice) when it exits the well.
http://en.wikipedia.org/wiki/Methane_hydrate
Register to reply
Related Discussions
Velocity of a water jet given water pressure and diameter? Advanced Physics Homework 3
Water pressure General Physics 19
Water Pressure Calculation with atmospheric pressure corrections General Physics 7
Air Pressure and Water Pressure Introductory Physics Homework 1
Water depth pressure against air pressure Classical Physics 1
