Fun, but difficult mechanics question
  • Thread starter Thread starter wd4gdz
    Fun Mechanics
The problem involves two stones thrown vertically upward with the same initial speed, where the second stone is thrown after a delay. Participants are tasked with determining the time and height at which the stones are at the same position, as well as the speed of the second stone at that moment.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the equations of motion for the stones, attempting to set their heights equal to find the time they meet. Some participants provide calculations and substitutions based on the given values, while others express uncertainty about how to proceed with subsequent parts of the problem.
There is active engagement with the problem, with some participants providing calculations for the time at which the stones are at the same height. Others are seeking guidance on how to approach the next parts of the problem, indicating a mix of understanding and confusion.
Participants are working under the constraints of a homework assignment, which may limit the amount of direct assistance they can receive. The discussion reflects varying levels of confidence in applying the relevant physics concepts.
wd4gdz
Any help would be greatly appreciated.
Thanks in advance.
A stone is thrown vertically upward at a speed of 45.50 m/s at time t=0. A second stone is thrown upward with the same speed 3.810 seconds later.
1) At what time are the two stones at the same height?
2) At what height do the two stones pass each other?
3) What is the upward speed of the second stone as they pass each other?
I'm pretty sure I could do #2 and #3, as long as I got some help first on #1.
--Billy
h1 = v*t - .5*g*t^2
h2 = v*(t-3.81) - .5*g*(t-3.81)^2
if h1=h2 , then
t = v/g + 3.81/2
if we have g = 10.0 and v = 45.50 , we get
t=6.455 seconds
Here, Ill write it out fully for you (with units), since Rogerio already solved it:
[tex]d_1 = Vt + \frac{1}{2}at^2[/tex]
[tex]d_2 = V(t-3.810s) + \frac{1}{2}a(t-3.810s)^2[/tex]
[tex]d_1 = d_2[/tex]
[tex]Vt + \frac{1}{2}at^2 = V(t-3.810s) + \frac{1}{2}a(t-3.810s)^2[/tex]
subbing in your values:
[tex](45.5m/s)t - (4.9m/s^2)t^2 = (45.5m/s)(t-3.810s) - 4.9m/s^2(t-3.810s)^2[/tex]
[tex](45.5m/s)t - (4.9m/s^2)t^2 = ((45.5m/s)t - 173.4m) - 4.9m/s^2(t^2 - (7.62s)t + 14.5s^2)[/tex]
[tex]-(4.9m/s^2)t^2 = - 173.4m - 4.9m/s^2(t^2) + (37.3m/s)t - 71.05m[/tex]
[tex]173.4m + 71.05m = (37.3m/s)t[/tex]
[tex]244.45m = (37.3m/s)t[/tex]
[tex]\frac{244.45m}{37.3m/s} = t[/tex]
[tex]t = 6.55s[/tex]
I have this same problem. I got the first part, but I have no idea where to start for the second part. Can someone give me a hint?
If you did the first part, then you know how to write the height as a function of time. And you now have the time. Plug it in!
