Troubleshooting MOS Transistor: Importance of Heavily Doped Regions
  • Thread starter Thread starter lostinxlation
The discussion emphasizes the critical role of heavily doped regions in MOS transistors, specifically for substrate tap (nMOS) and well tap (pMOS) connections. It establishes that connecting GND to p+ in nMOS and VDD to n+ in pMOS is essential to avoid issues such as the formation of Schottky diode junctions, which can block signals and hinder current flow. The necessity for heavy doping is highlighted as it ensures an ohmic contact at the metal-semiconductor interface, preventing rectifying contacts that would disrupt device functionality.
  • Understanding of MOS transistor structure and operation
  • Knowledge of semiconductor doping levels and their effects
  • Familiarity with ohmic versus rectifying contacts
  • Basic principles of electrical connections in semiconductor devices
  • Study the principles of ohmic contacts in semiconductor devices
  • Explore the effects of doping levels on MOS transistor performance
  • Learn about Schottky diodes and their implications in circuit design
  • Read about CMOS fabrication techniques and best practices
Electrical engineers, semiconductor device designers, and students studying integrated circuit design will benefit from this discussion, particularly those focused on optimizing MOS transistor performance and understanding fabrication techniques.
lostinxlation
hi
Looking at the cross section of MOS transistor, substrate tap(nMOS) and well tap(pMOS) are done on heavily doped regions. Basically, GND is connected to p+ in nMOS, and VDD is connected to n+ in pMOS.. What could be a problem if we don't have heavily doped regios for substrate and well tappings and VDD and GND are directly connected to n- well and p- substrate ?
The reason for heavy doping in the well regions is to establish an *ohmic contact*. All semiconductor devices such as diodes, bjt, IC, etc. use this method. At an interface where a semiconductor must be connected to the outside world through a lead or bond wire (layer to layer interconnect), a rectifying contact won't work. When a semiconductor is bonded to a metal, a Schottky diode junction can be formed if the semicond doping is not heavy enough.
Such a diode junction will block a signal in 1 direction, something we may not want. Visualize a bjt or FET. The lead wire into the collector or drain can form a diode. Likewise for the lead wire in the emitter or source. We now have 2 diodes in opposite directions, meaning that no substantial current can be realized. Heavy doping makes the metal-semicond interface non-rectifying, aka "ohmic".
As far as tying the substrate to ground (actually tied to the source), I've seen cases where the substrate is not tied. A good book on CMOS fabrication will explain in detail the reasons for doing so. I hope I've helped.
Claude
15K
  • · Replies 19 ·
11K
  • · Replies 22 ·
