Differential equation, Laplace transform
The discussion focuses on solving the differential equation x''(t) + 7x'(t) + 10x(t) = sin(3t) using the Laplace transform method. The solution involves finding the Laplace transform X(s) and applying partial fraction decomposition, resulting in coefficients A = -21/442, B = 3/442, C = -1/34, and D = 1/13. The final expression for x(t) is x(t) = -21/442 cos(3t) + 3/442 sin(3t) - 1/34 e^(-2t) + 1/13 e^(-5t). The discussion also highlights a common mistake regarding the factor of 3 in the sine term's Laplace transform.
  • Understanding of differential equations and their standard forms
  • Familiarity with Laplace transforms and their properties
  • Knowledge of partial fraction decomposition techniques
  • Basic calculus, including differentiation and integration of functions
  • Study the properties of Laplace transforms in detail
  • Learn about solving higher-order differential equations using Laplace transforms
  • Explore the application of partial fraction decomposition in different contexts
  • Practice solving differential equations with various forcing functions
Students and professionals in mathematics, engineering, and physics who are tackling differential equations and seeking to enhance their understanding of Laplace transforms and their applications.
rayman123
solve the differential equation by using Laplace transform
[tex]x^{''}(t)+7x^{'}(t)+10x(t)=sin3t[/tex]
[tex]x(0)=0, x^{'}(0)=0[/tex]
[tex]X(s)s^2+X(s)7s+X(s)10=\frac{3}{s^2+9}[/tex]
then i get
[tex]X(s) = \frac{3}{s^2+9}\cdot\frac{1}{(s+5)(s+2)}[/tex]
[tex]\frac{3}{(s^2+9)(s+5)(s+2)}=\frac{As+B}{s^2+9}+\frac{C}{s+5}+\frac{D}{s+2}\\<br /> \begin{cases}A+C+D=0\\7A+2C+B+5D=0\\10A+7B+9C+9D=0\\10B+18C+45D=3\end{cases}\Rightarrow \begin{cases}A=-\frac{21}{442}\\B=\frac{3}{442}\\C=-\frac{1}{34}\\D=\frac{1}{13}\end{cases}[/tex]
[tex]x(t) = =-\frac{21}{442}cos3t+\frac{3}{442}sin3t-\frac{1}{34}e^{-2t}+\frac{1}{13}e^{-5t}[/tex]
1) well i made a quck check (used other method to calculate A, B) to se if the are correct
and this is what i get
[tex]x=A\cos3t+B\sin3t[/tex]
[tex]x'=-3A\sin3t+3B\cos3t[/tex]
[tex]x''=-9A\cos3t-9B\sin3t[/tex]
and from this i obtain
[tex]A=-\frac{21}{442}[/tex]
[tex]B=-\frac{1}{442}[/tex]
can someone please show me where did I make a mistake??
[tex] X(s) = \frac{-3(7s-1)}{442(s^2+9)}\ + \frac{1}{13(s+2)}\ - \frac{1}{34(s+5)}\ }<br /> <br /> \begin{cases}A=-\frac{21}{442}\\B=\frac{3}{442}\\C=-\frac{1}{34}\\D=\frac{1}{13}\end{cases}<br /> correct [/tex]
[tex] x(t) = \frac{1}{442}(sin(3t)-21cos(3t))\ + \frac{e^{-2t}}{13}\ - \frac{e^{-5t}}{34}\[/tex]
You forgot about the factor of 3 on the top of the Laplace transform of sine
[tex]\frac{B}{s^2+9} = \frac{3/442}{s^2+9} = \frac{1}{442}\left(\frac{3}{s^2+9}\right) \rightarrow \frac{1}{442} \sin 3t[/tex]
As for the sign of that term, I'll let you track that down yourself. :-p
