If you spin a cylindrical magnet will anything happen to its magnetic field?
Spinning a cylindrical permanent magnet around its central axis does not alter its external magnetic field. The magnetic poles, located at the ends of the cylinder, maintain a symmetric field regardless of the rotation direction or speed. Even when the magnet is flipped like a coin, the overall magnitude and shape of the magnetic field remain unchanged, confirming that the magnetic domains do not affect the external field during rotation.
  • Understanding of magnetic fields and poles
  • Familiarity with permanent magnets and their properties
  • Basic knowledge of magnetic domains
  • Concept of symmetry in physical systems
  • Research the behavior of magnetic fields in rotating systems
  • Explore the principles of magnetic domain alignment in permanent magnets
  • Study the effects of rotation on electromagnetic fields
  • Investigate applications of rotating magnets in technology
Physicists, engineering students, and anyone interested in the principles of magnetism and its applications in technology.
TCS
If the magnetic poles are at the ends of a perfectly symmetric permanent magnet cylinder and and you spin the cylinder around its central axis, will anything happen to the magnetic field?
I feel like something should happen since the magnetic domains are revolving around, but the field is symmetric about the axis.
For permanent cylindrical magnets, if the poles are on the flat surfaces, if you spin the cylindrical magnet on its axis, clockwise or counterclockwise or both at regular/rapid frequency, pulses, nothing will happen to the magnetic field, it won't change to the outside observer.
If you spin the cylindrical magnet in a way for example, if it's a disc and you flip it like coin, the magnetic field will rotate with it but the overall magnitude and field shape will remain the same.
  • · Replies 23 ·
