Can a Subset of Questions Appear Exactly Once in Original and New Worksheets?
  • Thread starter Thread starter talolard
    Combinatorics
The problem involves a set of 50 questions from which 10 worksheets are created, each containing 5 questions. At the end of the semester, a new set of 10 worksheets is generated using the same questions, but sorted by difficulty. The task is to prove the existence of a subset of 10 questions that appear exactly once in one worksheet from each of the two groups.
  • Participants discuss the isomorphic nature of the problem and the use of a binary matrix to represent the relationships between questions in the worksheets. There are attempts to understand the implications of the determinant of the matrix and its relation to permutations. Clarifications are sought regarding the representation of questions across the worksheets.
The discussion is ongoing, with participants exploring various interpretations of the problem and the mathematical concepts involved. Some guidance has been offered regarding the structure of the matrix and the conditions under which the determinant may be zero. However, there is no explicit consensus on the solution yet.
Participants are navigating through potential misunderstandings about the problem's requirements, particularly regarding the representation of questions across the worksheets. There is also a mention of translation issues affecting clarity.
talolard
My professor has 50 questions. In the beginning of the semester he makes 10 work sheets each with 5 questions. At the end of the semester, he makes 10 new worksheets from the same quetions, this tiem sorted by difficulty.
Prove that there exists a subset of 10 question in which each question apeared exactly once in one of the original worksheets and in one of the new worksheets
The question is isomorphic to taking 50 different balls, labeling 5 with the number 1, labeling 5 with the number 2 etc until 10, and then repeating the process with a different colored pen.
We have created 50 unique ordered pairs. We can create a 10 by 10 matrix and label 1 in the i,jth place if that ordered pair exists in our collection and 0 if it does not. Then we have a 10 by 10 binary matrix.
We can notice that if the determinant of the matrix is non 0 then there exists some sub-group of the 50 balls that has two appearances of each of the numbers 1 to 10. This is from the definition of the determinant:
In our case, the determinant sums the number of permutations who's product is not zero. If such a permutation exists then a sub-set such as we are looking for exists.
The determinant is zero if the matrix is triangular (without entries on the diagonal) or if there are exactly two permutation, one even, one odd, whos product is non zero.
The matrix can not be triangular sicne there are 50 entries but only 45 entries in each triangle.
How do I prove that there can not be a pair of an even and odd permutation.
To clarify: the question asks you to show there are 10 questions that appear in the same numbered spot (between 1 and 5) on the old sheet and new sheet?
No. That there are ten questions such that in total every sheet out of twenty has exactly one question representing it.
I still don't understand. What does it mean for a question to represent a sheet?
I'll rephrase it, i apologize, I'm translating.
There are 50 questions. The profesor takes 5 and puts them ona sheet and then the next five and the next five until 10 sheets are created. Let's cal it group A. Each sheet has different questions on it.
Aftrewards, he takes the same 50 questions and makes different work sheets with them, again 10 sheets with 5 questions each. This is group B
You (I) need to prove that there is some group of 10 questions such that each question belongs to one sheet in group A and one sheet in group B and each sheet in each group is represented, i.e. a question from each sheet is in the group.
In a 10 by 10 matrix, there are 55 entries including the main diagonal, so the matrix can be triangular purely on those grounds. I haven't thought this through, but you should use the fact that every test has five questions.
Ok, I got it.
The determinant can only be zero if there are two different permutations, each of which satisfies the problem. So either way we are done.
  • · Replies 32 ·
  • · Replies 29 ·
