Mars Climate Orbiter probe crashed into the surface of Mars
The Mars Climate Orbiter probe crashed into Mars in 1998 due to a critical navigation error stemming from a unit conversion issue. NASA navigators utilized SI units for course corrections, while the probe's software operated in British units. This discrepancy led to the probe's failure to enter orbit, highlighting the importance of consistent unit usage in engineering. The inquiry revealed that 1 Newton (N) equals approximately 0.2248 pounds (lb) when converted using the appropriate factors.
  • Understanding of SI and British unit systems
  • Basic knowledge of force units: Newtons and pounds
  • Familiarity with unit conversion techniques
  • Basic physics principles related to motion and force
  • Research unit conversion methods between SI and British systems
  • Learn about the implications of unit errors in engineering projects
  • Study the principles of spacecraft navigation and trajectory planning
  • Explore case studies of engineering failures due to unit discrepancies
Engineers, aerospace professionals, students in physics or engineering disciplines, and anyone interested in the importance of accurate unit conversions in technical fields.
Whatupdoc
In 1998, the Mars Climate Orbiter probe crashed into the surface of Mars, instead of entering orbit. The resulting inquiry revealed that NASA navigators had been making minor course corrections in SI units, whereas the software written by the probe's makers implicitly used British units. The unit of force in the SI system is the Newton (N), which is defined in terms of basic SI units as 1 N = 1 kg * m/s^2. The unit of force in the British system is the pound (lb), which is defined in terms of the slug (British unit of mass), foot (ft), and second as 1 lb = 1 slug * ft/s^2.
Find the value of 15.0 N in pounds. Use the conversions
1 slug = 14.59 kg and 1ft = 0.3048m. Express your answer in pounds to three significant figures.
i wouldn't say that I am good at unit conversions, but i can do it, but with this question, it just confuses me. can someone help me with this problem?
1lb=(14.59kg)*(0.3048m)/s^2=(14.59*0.3048)kg*m/s^2=(14.59*0.3048)N
1N=(1/(14.59*0.3048))lb
you should manage the rest..
thanks a lot! that helped
13K
12K
  • · Replies 18 ·
37K
