When is dA not integrated into A for Gauss' law?
Gauss' Law is primarily applicable when the electric field (E) is uniform and perpendicular to the surface (S) being integrated. In cases of complex geometries or non-constant fields, more in-depth integration is required. If E is not perpendicular, the integration involves the cosine of the angle between E and the surface normal. For non-uniform fields, one must integrate E with respect to the area element (dA) to accurately determine the flux. Overall, Gauss' Law is most effective in scenarios with high symmetry where E can be treated as constant.
glennpagano
I have been studying Gauss' law and almost all of the problems I have been doing just have me integrate dA alone into A. I was wondering when do you actually have to do some more in depth integration.
The problems are usually set up with some nice symmetry so you can do the integral trivially. If your area was some crazy shape, or if your b field was not constant then you would actually have to integrate.
In general,
\int_{\mathcal{S}}\textbf{E}\cdot d\textbf{a}=|\textbf{E}|A
is only true when \textbf{E} is uniform (constant) over the surface \mathcal{S}, and normal (orthogonal/perpendicular) to \mathcal{S} at every point on the surface.
What if it is not perpendicular? Then you will have E\oint cos \phi dA. Then you can just pull out the cosine then because it is constant when compared to dA. If the E is not constant then will you still have to integrate it? Do you have to make it with respect to dA first? The more info the better. Right now, for most occasions I see Gauss' law as EA=q/epsilon naught.
That isn't nessecarily true. As a simple counterexample, consider a uniform E-field in the z-direction, \textbf{E}=E_0\mathbf{\hat{z}} and integrate over a spherical surface of radius R.
\begin{aligned}\int_{\mathcal{S}}\textbf{E}\cdot d\textbf{a} &= E_0\int_0^{\pi}\int_0^{2\pi}\mathbf{\hat{z}}\cdot (R^2\sin\theta d\theta d\phi \mathbf{\hat{r}}) \\ &=E_0\int_0^{\pi}\int_0^{2\pi}R^2\sin\theta \cos\theta d\theta d\phi \\ & = 0 \\ &\neq 4\pi R^2E_0\cos\theta\end{aligned}
Gauss' Law (in integral form) is really only useful (for finding \textbf{E}) in those special cases where, due to symmetry, you can find a surface where \textbf{E} is uniform over the surface and orthogonal to it at every point.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
