Finding Vector Components in Different Directions
The discussion focuses on finding the vector components of the force vector \(\vec{F} = 2\hat{i} - 2\hat{j} + \hat{k}\) in specified directions. The first direction is given by the unit vector \((\hat{i} + \hat{j} - \hat{k})/\sqrt{3}\), and the second direction is defined by the vector \(3\hat{i} + 2\hat{j} - 6\hat{k}\). The solution involves calculating the projection of \(\vec{F}\) onto these vectors using the formula \(\frac{\vec{u}\cdot\vec{v}}{|\vec{v}|^2}\vec{v}\), where \(\vec{u}\) is the force vector and \(\vec{v}\) is the direction vector. The user confirms that the calculations yield consistent results for both directions, leading to a projection of \(\langle 2\hat{i}, -2\hat{j}, -\hat{k} \rangle\).
  • Understanding of vector notation and operations
  • Familiarity with the concept of vector projection
  • Knowledge of unit vectors and their significance
  • Basic trigonometry, specifically cosine functions
  • Study vector projection techniques in detail
  • Learn about the properties of dot products in vector mathematics
  • Explore applications of vector components in physics
  • Investigate the geometric interpretation of vectors and projections
Students studying physics or mathematics, particularly those focusing on vector analysis and force components, as well as educators looking for clear explanations of vector projections.
zooxanthellae
Find the component of the force [tex]\vec{F} = 2\hat{i} - 2\hat{j} + \hat{k}[/tex] in:
a) the direction [tex](\hat{i} + \hat{j} - \hat{k})/\sqrt{3}[/tex]
b) the direction of the vector [tex]3\hat{i} + 2\hat{j} - 6\hat{k}[/tex]
[tex]dir \vec{A} = \vec{A}/|\vec{A}|[/tex]
a) I broke [tex]\vec{F}[/tex] down into components [tex]<2\hat{i}, 2\hat{j}, \hat{k}>[/tex]. Then I figured that F goes [tex]2\hat{i}[/tex] in direction [tex]i[/tex], goes [tex]-2\hat{j}[/tex] in direction [tex]j[/tex], then goes [tex]-\hat{k}[/tex] in direction [tex]k[/tex], giving an overall Force component of [tex]<2\hat{i}, -2\hat{j}, -\hat{k}>[/tex].
b) I did the same thing and since the signs in each direction were the same as in a), I ended up with the same answer: [tex]<2\hat{i}, -2\hat{j}, -\hat{k}>[/tex].
It seems to make sense, but I am pretty uncertain, so I thought I would ask here.
Thanks!
What you are looking for is the projection of the force vector, [itex]\vec{u}[/itex] on the vector giving the direction, [itex]\vec{v}[/itex]. Imagine a line extended in the direction of the given vector to be projected on and a line segment representing the force vector, having the same beginning point. Dropping a perpendicular to the line from the end of the segment, you have a right triangle with hypotenuse the force vector. Since [itex]cos \theta[/itex] is "near side over hypotenuse", the "near side", the length of the projection, is [itex]|\vec{u}|cos(\theta)[/itex].
You also need to know that [itex]\vec{u}\cdot\vec{v}= |\vec{u}||\vec{v}|cos(\theta)[/itex] so that [itex]\vec{u}|cos(\theta)= \vec{u}\cdot\vec{v}/|\vec{v}|[/itex]. That is the length of the projection. To get it as a vector, multiply by the unit vector in the direction of [itex]\vec{v}[/itex], [itex]\vec{v}/|\vec{v}|[/itex] which gives
[tex]\frac{\vec{u}\cdot\vec{v}}{|\vec{v}|^2}\vec{v}[/tex].
(For the vector in (a), [itex]|\vec{v}|= 1[/itex], for (b), it is 7.)
So we're imagining a right triangle in which the given [tex]\vec{F}[/tex] is the adjacent side, and the hypotenuse is the line segment stretching from the origin to the point where a perpendicular from the end of [tex]\vec{F}[/tex] crosses the line formed by an infinite extension of [tex]<\hat{i} + \hat{j} - \hat{k}>/\sqrt{3}[/tex].
Then you say that the length of the projection is [tex]|\vec{u}|cos\theta[/tex]. What exactly is [tex]\vec{u}[/tex]?
  • · Replies 20 ·
  • · Replies 25 ·
29K
