Definition of a continuous function
The discussion centers around the definition of continuity for functions as presented in Schutz's "Geometrical methods of mathematical physics." Participants explore the implications of the definition and whether it adequately captures the concept of continuity, particularly in relation to neighborhoods and isolated points.
  • One participant questions the definition provided by Schutz, suggesting that it would be more appropriate to state that the open set of N should contain the image of a neighborhood of x.
  • Another participant argues that Schutz's definition allows for proving that neighborhoods around x must be included in the open sets of M.
  • A counterexample is presented to challenge the definition, illustrating a function that appears continuous under Schutz's definition but is not continuous in the traditional sense.
  • Concerns are raised about the treatment of isolated points in the definition, with one participant suggesting that the definition should account for such cases.
  • Another participant asserts that the definition is inadequate if it does not require an open set about x to be contained in an arbitrarily small open set around f(x).
  • One participant proposes a rephrased definition that would address concerns about isolated points while maintaining the essence of continuity.
  • A simple counterexample is provided, demonstrating a function that fails to be continuous at a point, which would be misclassified as continuous under the original definition.
  • It is noted that Schutz clarifies the definition later in the text, indicating that continuity involves neighborhoods, which may resolve some of the confusion raised in the discussion.
Participants express differing views on the adequacy of Schutz's definition of continuity, with some proposing alternative formulations. There is no consensus on whether the original definition is sufficient or whether it requires modification to properly account for neighborhoods and isolated points.
Participants highlight limitations in the original definition, particularly regarding its applicability to isolated points and the necessity of neighborhoods in the context of continuity. The discussion reflects a range of interpretations and challenges related to the definition's implications.
nicksauce
I am reading Schutz's "Geometrical methods of mathematical physics". He writes: "A map f:M->N is continuous at x in M if any open set of N containing f(x) contains the image of an open set of M." However, it seems to me that a more appropriate definition would be "... contains the image of a neighbourhood of x". Am I right, or am I missing something obvious?
I would think that with Schutz's definition, you'll be able to PROVE that neighbourhoods around "x" must be included in those "open sets of M".
Note, for example, that a discontinuity of value at f(x) will prevent the existence of there being any open set of N about it. I think..
Well the counter-example of the Schutz definition I'm thinking of would look something like this: http://imgur.com/ppE5t
But maybe I need to think about it some more...
Counterexample perhaps from R to R:
[tex] f(x) = \begin{cases}<br /> 1 & \text{if }x \in \mathbb{Q}\text{ and }x \geq 0, \\<br /> 0 & \text{if }x \notin \mathbb{Q}\text{ and }x \geq 0, \\<br /> 1 & \text{if }-1 < x < 0, \\<br /> 0 & \text{if }x \leq -1.<br /> \end{cases}[/tex]​
According to the given definition, f(x) is continuous everywhere.
What if x is an isolated point of M?
Was the definition not so written to cater for this eventuality?
No, that's not the issue. Clearly if you consider continuity at x and then forget to require an open set about x to be contained in an arbitrarily small open set about f(x), you have a worthless definition. I'm pretty sure the author meant to say "A map f:M->N is continuous at x in M if any open set of N containing f(x) contains the image of an open set of x in M."
That would satisfy nicksauce' qualms, without introducing a neighbourhood.
However the original question was should a neighbourhood be introduced and I think I answered that point since I don't think an isolated point has a neighbourhood, although it is defined to be an open set, thereby satisfying your form of words.
I found, like others, it quite hard to get my head round this particular statement of continuity, which differs subtly from the topological one I am more used to.
So I think you may have cracked it.
This is a simple counter example.
[tex] f:\mathbb{R}\to\mathbb{R}[/tex]
[tex] f(x) = x,\quad\quad x\neq 0[/tex]
[tex] f(0) = 1[/tex]
With Euclidian topology, [itex]f[/itex] is not continuous at [itex]x=0[/itex]. Now choose an arbitrary open set [itex]V\subset\mathbb{R}[/itex] such that [itex]1\in V[/itex] (that means [itex]f(0)\in V[/itex]). You can find an open set [itex]]1-\epsilon,1+\epsilon[[/itex], such that [itex]f(]1-\epsilon,1+\epsilon[)\subset V[/itex], so [itex]f[/itex] should be continuous at [itex]x=0[/itex] according to the strange definition now.
It is a mistake. But Schutz says it right at the following page (8):
Therefore this definition says that f is continuous at x0 if every d'''-nhbd of f(x0) contains the image of a d'''-nhbd of x0. Since these nhbd's are open sets, the new definition given in the previous paragraph contains the elementary-calculus definition as a special case.
  • · Replies 18 ·
