Which of the following statements are IMPOSSIBLE?
  • Thread starter Thread starter traveler7
    Impossible
The discussion revolves around identifying which statements regarding physical principles are deemed impossible. The subject area includes concepts from fluid mechanics, thermodynamics, and properties of vacuums.
  • Participants explore the implications of pressure differences in hydraulics, the concept of buoyancy, and the nature of temperature in a vacuum. Questions arise about the definitions and assumptions related to these statements, particularly regarding the behavior of substances during phase transitions and the conditions of a vacuum.
The discussion is active, with participants questioning the validity of marked statements and offering insights into the nature of temperature in vacuums and phase changes. Some participants express confusion and seek clarification on specific concepts, while others provide reasoning to support their views.
There is a lack of consensus on the assumptions regarding the vacuum chamber's conditions, as well as the implications of temperature during phase transitions. Participants reference idealized scenarios versus real-world conditions.
traveler7
Which of the following statements are IMPOSSIBLE? Choose all that apply.
___A perfectly functioning hydraulic had a pressure of 36 Pa in the fluid near the small piston and a pressure of 37 Pa in the fluid near the big piston.
___A 35 L container displaced 42 L of orange juice when partially submerged.
___A substance underwent melting during which its temperature remained constant at 33 °C.
___A 37 N brick was fully submerged in water. The buoyant force on the brick was 48 N. As a direct result, the brick was neutrally buoyant.
___Last Friday, the Sun heated the Moon via convection.
___The temperature inside a vacuum chamber was measured to be 3 °C.
Based on what I have learned this is my attempt:
_x__A perfectly functioning hydraulic had a pressure of 36 Pa in the fluid near the small piston and a pressure of 37 Pa in the fluid near the big piston.
_x__A 35 L container displaced 42 L of orange juice when partially submerged.
_x__A 37 N brick was fully submerged in water. The buoyant force on the brick was 48 N. As a direct result, the brick was neutrally buoyant.
_x__Last Friday, the Sun heated the Moon via convection.
Try defining temperature in a perfect vacuum.
So what is your question? Can you provide reasoning why the ones you marked are impossible?
A vacuum chamber does not necessarily hold a perfect vacuum, in fact it never does, not to mention black body radiation.
You are of course right. I'm too used to idealized questions. :)
well a vacuum chamber has no air,
so would it be 0 K meaning their is no motion in the particles...
so the vacuum one would be impossible too?
My other question is:
is this possible:
I know plenty of vacuum chambers that have air in them. The statement of the question is
"The temperature inside a vacuum chamber was measured to be 3 °C." There is no mention whether there is gas in it or not. Why do you assume that it contains a perfect vacuum which doesn't even exist?
is this possible:
What happens to the temperature of a substance when it undergoes a phase transition from solid to liquid? Think of melting ice.
I asked my teacher about a vacuum chamber today and he said that it contains no air
and thanks for the other one I understand it now
OK. Assume that the vacuum chamber has not even a single molecule of air. You stick a mercury thermometer in it. Originally the thermometer reads 3 oC. Will the mercury column drop and indicate a lower temperaure?
10K
