Matlab: variables different formats
  • Context: MATLAB
  • Thread starter Thread starter camimfajardo
    Matlab Variables
This discussion focuses on the limitations of MATLAB's format command, specifically version R2023a, which applies a single display format to all variables. Users seeking to display variables in different formats must implement formatting directly in their scripts or utilize the fprintf function for explicit formatting. The format command only alters the display and does not affect the internal storage of variables. For tailored variable presentation, coding adjustments are necessary.
  • Familiarity with MATLAB syntax and commands
  • Understanding of variable types and display formats in MATLAB
  • Knowledge of the fprintf function for formatted output
  • Basic scripting skills in MATLAB
  • Explore MATLAB's format command documentation for detailed usage
  • Learn how to use fprintf for custom variable formatting
  • Investigate MATLAB's data types and their display characteristics
  • Review best practices for scripting in MATLAB to manage variable formats
MATLAB users, data analysts, and engineers who need to manage and display variables in different formats within their scripts.
camimfajardo
Hi all,
I need some help with matlab. I am trying to set up different variables with different formats. For example: "format long", "format short eng".. etc.
My problems is that when I use the command "format", it assigns the selected format to all the variables. But I want to create a file where some variables have certain format, and some other variables have another format.
Thank you very much,
Regards,
Welcome to PhysicsForums!
Unfortunately, I don't believe that there is a simple way of doing this. Note also that MATLAB's format command only affects the way variables are displayed, not the way they're stored (or treated) internally:
http://www.mathworks.com/access/helpdesk/help/techdoc/ref/format.html
If you want to display certain variables in certain formats, I'd code that in the script you're using to process those in the first place (with format changes everywhere). That or just accept MATLAB's display (and be cognizant of the underlying structure).
Alternately, instead of displaying variables using the variable name, you can make use of the fprintf feature and C-style explicit formatting:
http://www.mathworks.com/access/helpdesk/help/techdoc/ref/fprintf.html
Good luck!
  • · Replies 18 ·
  • · Replies 22 ·
