Can I Define y and Explore Power Series Properties with This Sum?
The discussion centers around the use of power series and their properties, specifically in relation to the sum \(\sum_{n=1}^\infty \left(\frac{x}{3}\right)^{2n}\). Participants explore whether defining a variable \(y = \frac{x}{3}\) can facilitate the application of power series properties.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant proposes defining \(y = \frac{x}{3}\) and using the series \(\sum_{k=1}^\infty a_k(y)\) where \(a_k(y)\) is defined piecewise based on the parity of \(k\).
  • Another participant suggests that while this approach is valid, the convergence properties must be translated back to \(x\) by substituting \(y = \left(\frac{x}{3}\right)^{2}\).
  • A different participant offers a simplification of the original series to a geometric series, \(\sum_{n=1}^\infty \left(\frac{x^2}{9}\right)^n\), indicating it has a common ratio of \(\frac{x^2}{9}\).
  • Another participant agrees with the initial proposal and emphasizes its utility in solving problems without confusion.
Participants generally agree on the validity of defining \(y\) and using power series properties, but there are differing views on the necessity of translating convergence properties back to \(x\) and the approach to simplifying the series.
Some assumptions about convergence and the definitions of the series are not fully explored, and the implications of the simplifications are not resolved.
estro
[tex]\mbox {Suppose I have: } \sum_{n=1}^\infty (\frac {x} {3})^{2n}[/tex]
[tex]\mbox{Can I define } y= \frac {x} {3}[/tex]
[tex] a_k(y) = \left\{<br /> \begin{array}{c l}<br /> (y)^k, & \mbox{if } k= 2n\\<br /> \\<br /> (0)^k, & \mbox{otherwise}<br /> \end{array}<br /> \right.[/tex]
[tex]\mbox {And then use all the cool properties of power series on } \sum_{k=1}^\infty a_k(y)[/tex]
[I edited my question]
Of course, but the convergence properties you know are given in terms of [itex]y[/itex] then. You need to translate them back in terms of [itex]x[/itex]. Essentially, substitute [itex]y = (x/3)^{2}[/itex] everywhere.
The simpler thing to do is write this as
[tex]\sum_{n=1}^\infty \left(\frac{x^2}{9}\right)^n[/tex]
so it is a geometric series with "common ratio" of [itex]x^2/9[/itex].
Indeed you can, and that's how you can easily do problems without getting fooled like
[tex]\sum_{n=1}^{\infty} n^n z^{n^n}[/tex]
Thank you guys!
