| Thread Closed |
How to build a human powered generator |
Share Thread | Thread Tools |
| Jun17-10, 10:04 PM | #1 |
Hi all,
Sorry if this is an incorrect part of the forum. Living a relatively sedentary lifestyle, consuming a Western diet, living in an area where drivers see pedestrians/cyclists as moving targets to run over and after packing on a few pounds, it got me thinking. I'd like to (as a side-project) make a small device that can provide power while I'm sitting and pedaling. Here are some requirements that I'd like to have: * Balance the load. I can plug in my computer in one end and have a connection to a live outlet at the other. The idea being that I won't lose power to my box whenever I stop pedaling. If I do pedal, then I simply use less energy from the grid. * I need some way to keep track of how much I'm generating in terms of watts. * I need to be able to sit at a regular office chair (at home) and pedal away. * Ideally, the amount of pedaling I do will proportionally increase the amount of juice I generate and that I can vary the resistance (and increase the amount of power production) as I build up strength and can produce even more power. Like I said, this is a side-project. And I'd like to say that I'm a complete n00b to electronics (some exposure at work, some things that I picked up over time), so I'd like to cover that part first. Any books or tutorials out there that some of you might know of? I realize that this will take me months of on and off effort before I can even have a prototype with half of the previously mentioned requirements, but I don't expect this to be easy :) . |
| Jun17-10, 10:08 PM | #2 |
Recognitions:
1, Bike - already has the gears, pedals, drive train.
2, Trainer - basically a pair or rollers and a stand to hold bike wheel. used by us masochists to cycle inside in winter when it's snowing 3, Swap the magnetic brake on the trainer for a 12V DC generator 4, UPS - converts 12V battery power to 110V/60Hz and has a battery so your computer doesn't lose power when you do. 5, Cheap $5 bike computer will keep track of how far/how much power (not terribly accurate but do you care?) |
| Jun17-10, 10:12 PM | #3 |
| Jun17-10, 11:34 PM | #4 |
Recognitions:
| Jun18-10, 02:02 AM | #5 |
Mentor
I'm not sure the UPS idea will work. A UPS switches between two different power supplies, it doesn't draw from both at the same time. And a bike won't power a desktop PC on its own for very long unless you're Lance Armstrong.
| Jun18-10, 05:59 AM | #6 |
| Jun18-10, 08:26 AM | #7 |
Recognitions:
You could disconnect the 110V input and just use the battery (while it is charged by the bike) you should be able to do 250W which is enough for a small PC (at least with an LCD) |
| Jun18-10, 09:04 AM | #8 |
Try the Microsoft way.
| Jun18-10, 09:11 AM | #9 |
![]() Click me... |
| Jun19-10, 12:49 AM | #10 |
Mentor
Lance Armstrong is capable of putting out 500 watts for a long period of time. A good recreational rider, 300 watts. A relatively normal adult in decent shape, 150 watts. But this is all aerobic exercise. If you want to just peadle idly while sitting at a desk for a few hours, you can't expect to generate more than about 50 watts unless you are in very good shape. And if you could generate 50 watts for 4 hours a day, 5 days a week for a year, you'd generate about $7.50 worth of electricity at residential rates. |
| Jun19-10, 12:58 PM | #11 |
Recognitions:
On average we use over 10kJ of fossil fuels in production (and packaging transporting etc) per each 1kJ worth of supermarket food we consume! (and I’ve seen realistic calculations and statistics to support that figure). Now factor in the relatively low overall efficiency of a home generator and the biomechanical inefficiency and you'd probably end up with something like 50 to 100 kJ of fossil fuels used per 1kJ of energy returned to the grid. So the irony is that even a coal fired power station is far more environmentally friendly than this human power generator. |
| Jun19-10, 04:02 PM | #12 |
But I have all 3 major OSes. Mac OS 10.6, Vista Ultimae 64-bit and Ubuntu 9.04 (need to upgrade, haven't gotten around to it yet.) |
| Jun19-10, 04:07 PM | #13 |
| Jun19-10, 04:11 PM | #14 |
| Jun19-10, 04:31 PM | #15 |
The reason I brought it up was to begin to address the problem of how much power you'll get out of how much physical effort. |
| Jun19-10, 10:04 PM | #17 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: How to build a human powered generator
| Pedal Powered Generator | Electrical Engineering | 11 | ||
| Human powered circumnavigation | Earth | 0 | ||
| Human powered still - Nichrome wire | Electrical Engineering | 6 | ||
| How do you make a hand powered AC generator? | Classical Physics | 2 | ||
