| Thread Closed |
Time Needed for a Lake to Freeze Over |
Share Thread | Thread Tools |
| Jul21-03, 10:59 PM | #1 |
I have been rather unfortunate to attend a school with a physics department that uses Sears and Zemansky's University Physics textbook. I have been working unsuccessfully on the following problem (Chapter 15, #103 for those who have the book) for 2 days...
Show that the thickness of the ice sheet formed on the surface of a lake is proportional to the square root of the time if the heat of fusion of the water freezing on the underside of the ice sheet is conducted through the ice sheet Here is what I know... or think I know... heat current = dQ/dt = (kA(Th - Tc))/L That is the only equation I have that involves time; however I was always under the impression that I cannot seperate dQ/dt since dt is part of an expression representing the instantaneous heat flow, and not a single variable. |
| Jul22-03, 04:04 PM | #2 |
| Jul22-03, 06:52 PM | #3 |
That makes sense. I was wondering whether or not that was possible. I just remember my Calculus book saying to treat it as a single expression... but if it is bounded by a constant like -g, or in this case, heat flow (which should be constant for a given thickness), then I should be able to treat the dt as a single variable. Is it possible to do that in other situations? For instance, something without constant acceleration, heat flow, etc?
| Jul22-03, 07:07 PM | #4 |
Time Needed for a Lake to Freeze Overdv/dt=-g dv=-g dt ∫dv=-g∫dt v-v0=-gt v=v0-gt OK, now recall that v=dx/dt. dx/dt=v0-gt Note that on the right hand side we have not a constant, but a function of time. We can still separate the variables. dx=(v0-gt)dt and you continue with the integration. The same rule (separation of variables) is valid for your problem. |
| Jul22-03, 10:25 PM | #5 |
I think I got it...
dQ/dt = k((Th-Tc)/x) Q = Hf*m dQ/dm = dQ/dx dm = dx dQ = [del]Hf*dx dQ/dt = [del]Hf*(dx/dt) dQ/dt = k((Th-Tc)/x) = [del]Hf(dx/dt) xdx = k(Th-Tc)dt/[del]Hf [inte]xdx = [inte]k(Th-Tc)dt/[del]Hf (x^2)/2 = k(Th-Tc)t/[del]Hf + C x = [squ]2k(Th-Tc)t/[del]Hf x is proportional to [squ]t Does this look good? |
| Jul24-03, 02:58 PM | #6 |
| Jul27-03, 05:11 PM | #7 |
dQ/dx = dQ/dm
dQ/dt [x=] dx Is it ok to assume that dx = dm ? |
| Jul27-03, 06:22 PM | #8 |
| Jul27-03, 10:01 PM | #9 |
dm is the change in mass, and dx is the change in length. Since a change in length results in a change in mass I set dQ/dm = dQ/dx
| Jul28-03, 04:21 PM | #10 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Time Needed for a Lake to Freeze Over
| Calculated the time it takes for a liquid to freeze ?? | General Physics | 20 | ||
| Model to predict time needed to cool down steel billets. | General Engineering | 6 | ||
| Time for water to freeze in a pipe | General Engineering | 2 | ||
| Time needed for a lake to freeze over. | Advanced Physics Homework | 4 | ||
| Recent witness says Bear Lake monster 'is still alive and lurking' :Salt Lake Tribune | General Discussion | 0 | ||
