Block sliding down wedge (w/ friction), wedge on frictionless floor
The discussion revolves around a physics problem involving a 5 kg block sliding down a rough wedge with a mass of 10 kg, resting on a frictionless surface. The block's vertical velocity is 3.0 m/s and horizontal velocity is 6 m/s at a specific moment, leading to a calculated wedge velocity of 3 m/s to the right. Key concepts include the conservation of momentum, where momentum is conserved in one direction, and the acknowledgment that the rough surface implies friction, affecting mechanical energy conservation.
  • Understanding of Newton's laws of motion
  • Knowledge of conservation of momentum principles
  • Familiarity with kinetic and potential energy concepts
  • Basic trigonometry for angle calculations
  • Study the principles of conservation of momentum in two dimensions
  • Learn about the effects of friction on mechanical energy conservation
  • Explore the dynamics of inclined planes and their applications
  • Review problem-solving techniques for systems involving multiple bodies
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to understand complex motion scenarios involving friction and inclined planes.
vitus
A large Wedge with mass 10 kg rests on a horizontal frictionless surface (think right triangle on a unit circle, theta <90 deg.). A block with a mass of 5 kg starts at rest (near the top) and slides down the inclined surface of the wedge, which is rough (does this imply friction?). At one instant the vertical component of the block's velocity is 3.0 m/s and the horizontal component is 6 m/s. At that instant the velocity of the wedge is:
None provided, here's what I know:
Mass of the block = Mb = 5 kg
Mass of the Wdge = Mw = 10 kg
theta = tan^-1(3/6) ~ 26.56 deg. (from x-axis)
Velocity of the block = (3^2 + 6^2)^(1/2) ~ 6.7m/s @ 206.56 deg.
Here's what I think is possibly useful:
conservation of energy:
KEb + PEb + KEb + KEw = Me (total mechanical energy)
(Kinetic energy of the block, Potential energy of the block, etc for the wedge)
Sum of Forces:
SUM(Fx) = 0
(Sum of forces in the X-axis is zero)
SUM(Fy) = 0
Conservation of momentum:
MbVbi + MwVwi = MbVbf + MwVwf
(sum of the initial mass x velocity of objects = sum of final mass x velocity of objects)
I've taken several approaches
1) Reference Frames
Vb/e = Vb/w + Bw/e
(Velocity of the block w/ respect to Earth is the sum of Vblock w/ res. to wedge + wedge to earth)
6 m/s = (gravity - friction here) + Bw/e
6 m/s = (Mb(g)cos(theta) - Fnus) + Bw/e
6 m/s = (5gcos(26.56) - (5gcos(26.56)us) + Bw/e
6 m/s = (1 - us) + Bw/e
except us is neither stated nor computable...
2) Conservation of Momentum
5(0) + 10(0) = 5(6.7) + 10(Vwf)
except everything starts at rest, yet end up moving so momentum isn't conserved here
3) Conservation of Energy
0.5Mb(Vbo)^2 + Mbgho + 0.5Mw(Vwo)^2 = 0.5Mb(Vbf)^2 + Mbghf + 0.5Mw(Vwf)^2
Here there is no inital KE so it becomes
Mbgho = 0.5Mb(Vbf)^2 + Mbghf + 0.5Mw(Vwf)^2
(5)g(ho) = 0.5(5)(6.7)^2 + (5)g(hf) + 0.5(10)(Vwf)^2
g(ho) = 0.5(Vbf)^2 + g(hf) + 0.5(10/5)(Vwf)^2
Lets choose the instant where the block hits h=0, so this removes g(hf) from the equation:
g(ho) = 0.5(Vbf)^2 + 0.5(10/5)(Vwf)^2
(g(ho) / 0.5(Vbf)^2)^(1/2) = Vwf
great, except for two catches. First what is the original height (ho) and what about the energy lost to friction (does the prof. mean there's frinction when he says rough?)
Just from basic reasoning, if the block is going 6m/s left as it slides and the ratio of masses is 1:2 then the wedge will go 3 m/s right, but I can't seem to get that answer...
btw, I already took the test this question was on and he gave me 4/5 points for the work showed and the explanation I gave above (even though the work didn't really fit with my explanation). I'm just curious as to how one would solve this problem.
Some comments:
- Yes, a rough surface does imply friction. Thus mechanical energy is not conserved.
- Momentum can be conserved in one direction, yet not conserved in another. (That's the key to solving this with barely any work at all.)
I see so it becomes
MbVbix + MwVwix = -MbVbfx + MwVwfx
which, since everything is at rest initially, becomes:
0 = -MbVbfx + MwVwfx
MbVbfx = MwVwfx
(5 kg)(6 m/s) = (10 kg)(Vwfx)
0.5(6 m/s) = 3 m/s
Seems rather obvious now that you point it out. Thanks.
  • · Replies 25 ·
9K
  • · Replies 23 ·
