| Thread Closed |
Stator ring coil and connection questions |
Share Thread | Thread Tools |
| Jun22-10, 06:45 PM | #1 |
Hello everyone:
I am trying to find a program or formula that will help me figure out how many windings, turns of coil, are needed per coil on a 6 coil steel stator ring powered by 3-phase AC power to get a certain magnetic field strength, about 1.3T. Is there any way that you could help me find out how many windings are needed per coil? Would I use the standard solenoid formula B=mu*N*L? Could I use a standard ac plug with one hot leg and one neutral to power my steel stator ring coils, 6 total, to create a rotating magnetic field? If so, how would I connect the coils together and how would I connect those interconnections to the one hot leg and one neutral leg? And how would this affect the number of turns needed for each coil? Which would be better, Using a DC power supply or AC power from a plug with one hot leg and one neutral leg? If DC is better to create the rotating magnetic field, how would I connect the six coils together and how would I connect those interconnections to a DC power supply Thanks so much for the help. Stephen |
| Jun22-10, 11:58 PM | #2 |
Before you start blowing breakers, I would suggest that you learn more about single phase motors and read up on fundamentals of 3 phase power generation. There is no way to connect your standard outlet to create 3 phase AC. |
| Jun23-10, 12:05 AM | #3 |
no no... I was wondering if I could use the outlet AC plug with one hot and one neutral leg to connect maybe 4 total coils of the steel stator ring instead of the six coils for three-phase AC power. Can I do that? Or would using DC be better? If so, how would you connect the coils together, a delta or star, and how would you connect the coils to a DC power supply to get a rotating magnetic field?
Also, is there a way to figure out how many turns per coil is needed on the steel stator ring with 4-6 coils to create a rotating magnetic field of a certain strength, about 1.3T? Would using DC or AC as a power source change the number of turns needed? Thanks. Stephen |
| Jun27-10, 06:57 PM | #4 |
DC will not work; there will not be a rotating field, only an electro-magnet.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Stator ring coil and connection questions
| Stator ring connection and coils question | General Engineering | 0 | ||
| A very simple stator ring question | General Engineering | 5 | ||
| Stator ring construction Help | Electrical Engineering | 0 | ||
| valuation ring questions | Linear & Abstract Algebra | 1 | ||
| metal ring repelled from AC coaxial coil | Introductory Physics Homework | 0 | ||
