Simpson method question(numerical analysis)
  • Thread starter Thread starter nhrock3
    Analysis Method
The discussion revolves around Simpson's method in numerical analysis, specifically focusing on the interpretation of "panels" and the use of points in the approximation of functions.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the definition of a "panel" in the context of Simpson's method, questioning how three points relate to the concept of intervals and coefficients in quadratic approximations.
Participants are actively engaging with the definitions and mathematical expressions involved in Simpson's method. Some have provided clarifications about the use of points and intervals, while others are seeking further understanding of how these elements fit together in the formula.
There appears to be some confusion regarding the terminology used, particularly the term "panel" and its relation to intervals and the number of points required for calculations in Simpson's rule.
nhrock3
i have been told that simpson with 3 points is a single panel
why??
a pannel is the distance between to points
so if we have 3 points then we have 2 panels
http://i48.tinypic.com/nlc4t1.jpg
can't view the link clearly and what do you mean by pannel?
Simpson's method works by approximating a function by a "piecewise quadratic". If I understand your use of "panel" correctly, it is one of the quadratic pieces.
Since a quadratic, [itex]y= ax^2+ bx+ c[/itex], has three coefficients to be determined, one quadratic, one panel, requires three points, not two, to determine those three coefficients.
The "trapezoid method", where we approximate the function by a piecewise linear function, y= ax+ b, requires only two coefficients to be determined and so each "panel" requires two points.
so how they use those three points in the formula
i can't see where they use them on the arrow pointed formula
In the last equation, the three points are (-1, f(-1)), (0, f(0)), and (1, f(1)).
The equation could be rewritten as
S1 = (1/3)[f(-1) + 4f(0) + f(1)].
so a pannel is not an interval
a panel in simpsons rule is 3 points (which has two intervals between them)
i tried to get to your expression by the formula
if we have three points then we have 2 sub intervals
[tex]h=\frac{b-a}{m}=2/2=1[/tex]
[tex]x_h=a+kh=-1+k[/tex]
[tex]s(f,h)=\frac{h}{3}(f(a)+f(b)+\frac{2h}{3}\sum_{k=1}^{m}f(x_{2k})+\frac{4h}{3}\sum_{k=1}^{m}f(x_{2k-1})=[/tex]
[tex]\frac{1}{3}(f(-1)+f(1)+\frac{2}{3}\sum_{k=1}^{m}f(x_{2k})+\frac{4}{3}\sum_{k=1}^{m}f(x_{2k-1})=[/tex]
[tex]\frac{1}{3}(f(-1)+f(1)+\frac{2}{3}[f(x_2)+f(x_4)]+\frac{4}{3}[f(x_1)+f(x_3)]=[/tex]
you see that it requests 4 points
and not
x_0 x_1 x_2
In Simpson's rule, you divide an interval [a, b] into n subintervals of equal length. In each subinterval you use function values evaluated at three points: the left endpoint, the middle, and the right endpoint.
Instead of getting lost in the summation symbols, work out for yourself for some simple function and an interval [0, 1] divided into four subintervals. What does Simpson's rule give you for this situation?
