Thread Closed
resistor power rating
Share Thread Thread Tools
Jun26-10, 06:39 PM   #1
i have a question about resistors. i thought they were described by their resistance - 20 ohm, 40 ohm, 2 Megaohm, etc.
how come I see "power" values on resistors? for example my lightbulb says 40 watts. but i thought the power is simply P = V^2/R and that would depend the voltage of my power outlet whatever that happens to be. The power would only be partially determined by the lightbulb. so what does it mean to see a power value on a resistor?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Jun26-10, 06:52 PM   #2
Q, If you put too much current through your resistor it will get too hot. There are different resistor types intended for different degrees of power they need to dissipate. Maybe P=I^2 * R, so it's a current limiting rating.
Thread Closed
Thread Tools
Similar Threads for: resistor power rating
Thread Forum Replies
Why doesn't a resistor burn up when its power rating is exceeded? Introductory Physics Homework 1
Maximum licensable core power rating Nuclear Engineering 1
Power supply -- Importance of amp Rating?? Electrical Engineering 3
Power and Power Dissipated by a resistor .. in layman's terms General Physics 20
Tolerance rating on a 0 Ohm resistor??? Electrical Engineering 6
