Voltage at a Point: Understanding Ground in Circuits
  • Thread starter Thread starter quantum13
    Point Voltage
The discussion clarifies the concept of "ground" in electrical circuits, emphasizing that ground serves as an arbitrary reference point for measuring voltage. A voltmeter measures voltage at a specific point relative to this ground. The conversation highlights that in simple circuits, such as those with a battery and resistor, voltage can be calculated at various points, with ground typically connected to the negative terminal of the EMF source. Understanding this concept is crucial for analyzing voltage drops across components in a circuit.
  • Basic understanding of electrical circuits
  • Familiarity with voltage measurement techniques
  • Knowledge of Ohm's Law
  • Concept of reference points in electrical engineering
  • Study the operation of voltmeters and their application in circuit analysis
  • Learn about voltage drops across resistors using Ohm's Law
  • Explore the concept of ground in more complex circuits
  • Investigate different types of EMF sources and their configurations
Electrical engineering students, hobbyists working on circuit design, and anyone interested in understanding voltage measurement and reference points in electrical circuits.
quantum13
I was reading a book on circuits and came across the phrase "a voltmeter can measure the voltage at a point with respect to ground"
I don't actually understand what this is supposed to mean in circuitry though. Don't people usually refer to the voltage drop across a resistor?
I suppose this could be a homework question so mods can move it; in that case there is a simple circuit with battery and a resistor, how do you calculate voltage "at a point" in between?
edit: i realized that "ground" is just an arbitrary point defined in a circuit, i missed that part reading it hehe
ground is a common reference point that is chosen arbitrarily in the circuit. If there is only one EMF source, it is customary to be attached to its negative end.
9K
  • · Replies 19 ·
