Why Does Tongue Resistance Change When Measured with a Multimeter?
  • Context: High School
  • Thread starter Thread starter bos1234
    Resistance
The discussion revolves around the variability of tongue resistance when measured with a multimeter, particularly focusing on the effects of moisture and the nature of the tongue as a conductor. Participants explore the implications of these measurements and the factors influencing resistance readings.
  • One participant notes that the resistance of the tongue is not constant and questions why it should be stable at 50k ohms.
  • Another participant suggests that the variability in resistance may be due to the moisture level of the tongue, indicating that a dry tongue leads to slower changes in resistance readings.
  • A different viewpoint humorously proposes that the resistance could stabilize based on external factors, such as hair standing up, and suggests that the pressure applied by the probes could also affect the readings.
  • One participant introduces the idea that electrochemical reactions could occur when metal probes are placed in contact with saliva, which may influence resistance measurements.
Participants express differing views on the stability of tongue resistance and the factors affecting it. There is no consensus on the reasons behind the observed changes in resistance or the implications for the multimeter's accuracy.
Participants highlight the dependence of resistance readings on moisture levels, pressure applied, and potential electrochemical reactions, but these factors remain unresolved in terms of their exact contributions to the measurements.
This discussion may be of interest to individuals exploring electrical conductivity in biological tissues, those curious about the operation of multimeters, or anyone investigating the effects of moisture on resistance measurements.
bos1234
I recenlty bought a very cheap multimeter for $10.
I switched the multimeter to ohms 2000k and stuck the probes on my tongue. The initial value was 400k and rapidly increased until it exceeded 2000k for which my multimeter cannot read.
Then I dried the tip of my tongue completely and probed it again. Now the readings increase much slower and sometimes even drop at certain stages.
My question
1. Why is the resistance not constant? I read it should be stable at 50k
2. And why my otngue is dry why is the rate of resistance slower?
Is something wrong with the MM?
If your aim is to check the working of your multimeter, why can't you measure a known resistance and cross check the values. Why i am saying this is, one cannot be sure about resistance of tongue or any thing like that.
I suspect that maybe once your hair was all standing perfectly straight up, the resistance started to stabilize. Depending on how much hair gel you use, the 2nd time you tried, it was already standing up so it didn't vary as much. You might just have to try a higher voltage. Perhaps using a the 2 wires from an outlet? :)
Sorry ... couldn't resist. :) It was just funny hearing about sticking electrical wires on your tongue. I agree with n.karthick that your tongue is not a stable resistor. How well it conducts completely depends on how wet/dry it is plus how hard you push the wires onto it and I imagine even the shape of it could affect it (which changes from moment to moment).
Saliva is acid.
When you stick metal in acid all sorts of interesting electrochemical things happen. It depends on what the metal is and what the acid is and it's concentration plus any other currents and voltages that might be in the circuit (The battery in your meter.)
Try tasting the terminals of a small battery (and I mean SMALL)
  • · Replies 105 ·
14K
  • · Replies 24 ·
