What Distribution Best Models Passenger Queue Arrivals Within Fixed Timeframes?
  • Context: Graduate
  • Thread starter Thread starter mikey2322
    Queue
The discussion focuses on modeling passenger queue arrivals using statistical distributions within a fixed timeframe. The Poisson distribution is identified as the most suitable model for independent arrival events, allowing for variable mean rates during specified intervals. The Gamma distribution describes actual arrival times, while the Exponential distribution represents the time between arrivals. Alternatives like the Negative Binomial distribution are suggested for scenarios where the mean and variance of arrival rates differ.
  • Understanding of Poisson distribution and its parameters
  • Familiarity with Gamma and Exponential distributions
  • Knowledge of Negative Binomial distribution
  • Basic concepts of statistical modeling and random variables
  • Research the application of Poisson distribution in queuing theory
  • Explore the characteristics and applications of Gamma distribution
  • Study the Negative Binomial distribution and its use cases
  • Investigate statistical software tools for modeling distributions, such as R or Python's SciPy library
Data analysts, operations researchers, and anyone involved in optimizing queue management and passenger flow in transportation settings.
mikey2322
Hi,
I am trying to assign a distribution to the the rate at which passengers enter a queue over a period of time. The period of time is to remain constant. Passengers start arriving 4 hours before a flight and stop arriving at the scheduled time of departure.
I have been using a Weibull distribution but I find that you cannot lock down the distribution to stay within the time period easily. I am looking for a distribution that I can lock to a certain time period and where I can alter the amplitude and wave length similar to WEIBULL. Is there a distribution curve that will allow this?
Mike
In problems (random events within a fixed time interval) like this the Poisson distribution is usually used. The basic assumption is that the events (arrivals) are independent of each other.
mathman is correct that Poisson distributions are often used to model arrivals, but I'm confused by your following comment:
"a distribution that I can lock to a certain time period".
By this comment do you mean you want arrivals to completely start/stop at certain points, but that you want arrivals to be random within that timeframe, but at a different mean rate depending on the time (for example, the mean rate of arrival of passengers for a 2pm flight is 0 per hour before 8am, 5 per hour from 8 to 10am, 9 per hour from 10 to 1pm, 3 per hour from 1 to 2pm, and 0 per hour thereafter)?
To do this, you could vary the mean/variance parameter (the lambda parameter) that defines a Poisson r.v. which represents the rate of arrivals within each timeframe, and make the probability of zero arrivals = 1 before 8am and after 2pm (for example).
The actual arrival times will follow a Gamma distribution, and the time between arrivals will follow a exponential distribution, but the rate of arrivals per hour will be Poisson.
If you don't want the mean rate and the rate's variance to be equal, you could use the Negative Binomial distribution or other distributions depending on the shape you believe the rate of arrivals follows in reality.
11K
