Contravariant components to covariant
The discussion revolves around the transformation of coordinates and the calculation of metric tensors in a defined coordinate system (s,t) derived from Cartesian coordinates. The user successfully derived contravariant coordinates (2, sqrt(2)) from the point (3,1) but encountered discrepancies when calculating covariant coordinates, initially obtaining (3, 2*sqrt(2)). A key correction was provided, indicating that the mixed components of the metric tensor should be 1/sqrt(2) instead of (2+sqrt(2))/2, which is crucial for accurate calculations.
  • Understanding of coordinate transformations in differential geometry
  • Familiarity with metric tensors and their properties
  • Knowledge of contravariant and covariant vectors
  • Basic skills in calculus and linear algebra
  • Review the derivation of metric tensors in different coordinate systems
  • Study the properties of contravariant and covariant vectors in detail
  • Learn about index notation and its applications in tensor calculus
  • Explore examples of coordinate transformations and their implications in physics
Mathematicians, physicists, and students studying differential geometry or general relativity, particularly those interested in coordinate transformations and tensor analysis.
cavus
Hi, everyone
I was playing with the coordinate transformations and metric tensors to get a feeling of how it all behaves, and got stuck with some basic problem I am hoping you can help me with.
So, I have defined a coordinate system (s,t), with the s axis going along the x-axis in the cartesian coordinates, and t axis going along the y=x line:
s = x-y
t = y*sqrt(2)
with inverse transformation:
x = s + t/sqrt(2)
y = t/sqrt(2)
If I am differentiating correctly, the metric tensor in these coordinates looks like:
1 (2+sqrt(2))/2
(2+sqrt(2))/2 1
g11 = g22 = 1,
g21=g12 = (2+sqrt(2))/2
Now, I pick a point (3,1) in cartesian coordinates, and transform it to my new frame, and get the contravariant coordinates as (2, sqrt(2)).
So far so good. What I am trying to do is find out what its covariant coordinates are going to be. I think, that covariant coordinates are supposed to be the lengths of orthogonal projections of the vector on the respective axes. From basic geometry, I get (3, 2*sqrt(2)).
The problem is that when I try to multiply my metric tensor by the contravariant vector, I get a different answer - (3+sqrt(2), 2+2*sqrt(2))
Clearly, there is something I am doing wrong here, but I can't figure out what it is :( Can somebody please help me spot the problem?
Thanks a lot for your help!
Your metric is wrong. The mixed components (g12 and g21) should be 1/sqrt(2).
Because you did not show how you got your metric tensor, I can't say where you went wrong, but if your check your index dropping with the correct metric, you'll see that it fits.
Hope, it helps ...
  • · Replies 31 ·
