Extimation of displacement in Frontal plane from sagital plane
  • Context: Graduate
  • Thread starter Thread starter btd
    Displacement Plane
The discussion centers on estimating displacement in the frontal plane using video recordings from the sagittal plane during treadmill walking. The researcher, Tanner, employs a 10 cm calibration marker on the subject's back to analyze center of mass displacement. However, the challenge arises due to the subjects' movement on the treadmill, which affects the accuracy of the displacement measurement. A suggested solution involves selecting a fixed point on the torso and adjusting for horizontal distance to improve measurement accuracy.
  • Understanding of biomechanics and center of mass concepts
  • Familiarity with video analysis techniques
  • Knowledge of calibration methods in motion capture
  • Experience with displacement measurement in kinematics
  • Research methods for calibrating video analysis in biomechanics
  • Learn about the use of motion capture systems for accurate displacement measurement
  • Investigate techniques for correcting for torso movement in gait analysis
  • Explore software tools for analyzing video data in biomechanics, such as Kinovea or Dartfish
This discussion is beneficial for biomechanics researchers, kinesiologists, and motion analysis professionals focused on gait analysis and displacement measurement techniques.
btd
estimation of displacement in Frontal plane from sagital plane
Hello everybody,
I hope I am posting this under right topic.
I am running a research project and we are recording videos of subjects from both frontal (back) and saggital (side) plane while they are walking on the treadmill.
I put 10cm long calibration marker on the back of the subject. This way, when I analyze the video recording I can calculate how much center of mass displaced during walking. But the problem is subjects do not walk on the same spot on the treadmill all the time. They go front and back and this makes my 10 cm, 8cm or 12cm (estimation) on the recording
I am just wondering if I measure the displacement from saggital recording, can this help to calculate how much it makes change on 10 cm in frontal recording.
or is there a another way?
Thanks
Tanner
I would suggest that you choose some point on the torso and subtract off the horizontal distance from that point to your control point to correct for movement of the torso.
(But if you are measuring from a marker on the back of the subject, that should already allow for movement of the body.)
Thanks a lot for your answer,
Actually, what I am trying to do is calculating the displacement of center of mass (located at S2 vertebrae) from a fixed point on the torso with just one camera recording frontal movements.
Would you explain what you mean by saying "subtract off the horizontal distance from that point to your control point"?
I really appreciate your help
Cheers
