Question about the conservation of momentum?
The discussion revolves around the concept of conservation of momentum in a vacuum, particularly in the context of a hypothetical scenario where a person appears in space without initial velocity. Participants explore the implications of moving limbs and the resulting effects on momentum and motion.
  • One participant questions whether they could move their arms or legs in a vacuum without initial momentum, suggesting that movement may not be possible without a source of momentum.
  • Another participant introduces the idea that spawning in space involves potential energy, implying that this energy could be converted to kinetic energy through movement, similar to everyday actions.
  • It is noted that flapping arms would result in the body moving in the opposite direction, indicating that momentum would be conserved in this action.
  • A follow-up question is posed about the consequences of moving just one arm, prompting speculation about how the rest of the body would respond to maintain the center of mass.
  • One participant humorously suggests that even extreme actions, like throwing one's head away, would also conserve momentum.
Participants express differing views on the feasibility of movement in a vacuum and the role of potential energy, indicating that multiple competing perspectives remain without a clear consensus.
The discussion does not address specific assumptions about the nature of potential energy or the mechanics of movement in a vacuum, leaving these aspects unresolved.
zeromodz
If I were to just spawn into a complete vacuum of space with no initial velocity (momentum). Disregarding the fact that I would die due to lack of pressure and oxygen, would I be able to move my arms or legs at all because I would have no place to take the momentum from?
Weird question.
If you spawned in space you must also spawn an awful lot of potential energy which defines what you are. Then what's the big deal that you then convert some of that potential energy to kinetic energy by flapping your arms? It's no different from what you do every day.
When you flap your arms your body will move in the opposite direction from the flapping - momentum will be conserved.
But what if you don't flap them, what if you just move one arm over? What would happen?
Then the rest of your body would move the opposite way such that your center of mass would remain the same.
:smile:
Then you could pull your head off and throw it away - that would conserve momentum too.
  • · Replies 30 ·
  • · Replies 53 ·
