Find Resoance Frequency for Electric Motor Mass of 100 kg
  • Thread starter Thread starter bullet_ballet
    Resonance
The discussion revolves around calculating the resonance frequency of an electric motor with a mass of 100 kg, supported by vertical springs that compress when the motor is installed. Participants are exploring the relationship between the spring constant, gravitational force, and the resulting frequency of resonance.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the formula for resonance frequency and question the values used for the spring compression. There is an exploration of the implications of using incorrect units and the fundamental understanding of the problem setup.
Several participants have identified potential errors in calculations and unit conversions. There is a recognition of the need to clarify the assumptions made regarding the spring compression and its impact on the resonance frequency. The discussion is ongoing with attempts to reconcile differing results.
Participants are working under the constraints of a homework problem, which may limit the information available for resolving discrepancies in calculations. The original poster's reference to a book solution suggests a need for alignment with established results.
bullet_ballet
"An electric motor of mass 100 kg is supported by vertical springs which compress by 1 mm when the motor is installed. If the motor's armature is not properly balanced, for what revolutions/minute would a resonance occur?"
I set my frame of reference at the end of the spring. Therefore, F = kx - mg = 0. To get resonance ω must equal ω0 which is √(k/m) or √(g/x). I know g to be 9.82 m/s² and x to be 1 mm. Therefore, √(g/x) = 31.3 rps or 1878 rpm. The book lists 955 rpm, so where did I go wrong?
you used x = 1 mm as if it was x = 1 m.
I see that I made the mistake of dividing g by .01m and not .001m, but that only makes the answer worse at 5950 rpm. My mistake is definitely more fundamental, but I can't see it.
sqrt(g/x) = sqrt( [ 9.80 m/s² ]/[ .001 m ] ) = 98.99 rad/s = [ 98.99 rad/s ][ 1/2pi rev/rad ][ 60 s/min ] = 945 rpm.
Thanks a lot.
  • · Replies 18 ·
